How to Fix A Warped Frisbee Disc
  1. How to Fix A Warped Frisbee Disc, How to Fix A Warped Frisbee Disc: step 1, image 1 of 2 How to Fix A Warped Frisbee Disc, How to Fix A Warped Frisbee Disc: step 1, image 2 of 2
    • Place the frisbee disc on a flat surface with the concave side facing up. Lay a towel down flat over the frisbee.
  2. How to Fix A Warped Frisbee Disc: step 2, image 1 of 1
    • Take the bowl and fill halfway full with water. Microwave until water is boiling.
    • The bowl will be hot, so handle it with care.
  3. How to Fix A Warped Frisbee Disc: step 3, image 1 of 1
    • Take the bowl with boiling water and place it on top of the frisbee and the towel.
  4. How to Fix A Warped Frisbee Disc: step 4, image 1 of 1
    • Add a textbook as a weight to sit on top of the bowl.
    • Let everything sit for 1 hour
  5. How to Fix A Warped Frisbee Disc: step 5, image 1 of 1
    • Remove any weights, the bowl, and the towel. Check to see if the disc is still warped.
    • If it is still warped repeat this process one more time.
The time taken to fix the warping on your frisbee may vary based on how thick the plastic is.
3 other people completed this guide.
Bryce Petersen
200 Reputation
1 Guide authored
Cal Poly, Team 30-5, Green Spring 2015 Member of Cal Poly, Team 30-5, Green Spring 2015
CPSU-GREEN-S15S30G5
5 Members
32 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 48
All Time: 10,615
