How to Fix Joy-Con Drift Without Disassembly
  1. How to Fix Joy-Con Drift Without Disassembly, How to Fix Joy-Con Drift Without Disassembly: step 1, image 1 of 2 How to Fix Joy-Con Drift Without Disassembly, How to Fix Joy-Con Drift Without Disassembly: step 1, image 2 of 2
    • Press and hold the black round button on the back of the Joy-Con, then slide it forward to remove.
  2. How to Fix Joy-Con Drift Without Disassembly: step 2, image 1 of 2 How to Fix Joy-Con Drift Without Disassembly: step 2, image 2 of 2
    • Open the 404B contact cleaner and insert the tube into the nozzle.
    Puede ser WD-40?
    John - Reply
  3. How to Fix Joy-Con Drift Without Disassembly: step 3, image 1 of 1
    • Push the Joy Stick to the side and hold.
  4. How to Fix Joy-Con Drift Without Disassembly: step 4, image 1 of 2 How to Fix Joy-Con Drift Without Disassembly: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to lift the rubber ring under the Joy Stick, and hold.
  5. How to Fix Joy-Con Drift Without Disassembly: step 5, image 1 of 2 How to Fix Joy-Con Drift Without Disassembly: step 5, image 2 of 2
    • Aim the contact cleaner's nozzle at the gap and spray 404B contact cleaner once or twice.
  6. How to Fix Joy-Con Drift Without Disassembly: step 6, image 1 of 3 How to Fix Joy-Con Drift Without Disassembly: step 6, image 2 of 3 How to Fix Joy-Con Drift Without Disassembly: step 6, image 3 of 3
    • Rotate the Joy Stick for 30 seconds to allow full penetration of the liquid inside.
  7. How to Fix Joy-Con Drift Without Disassembly: step 7, image 1 of 1
    • Wait 10 minutes for the liquid to dry completely.
  8. How to Fix Joy-Con Drift Without Disassembly: step 8, image 1 of 3 How to Fix Joy-Con Drift Without Disassembly: step 8, image 2 of 3 How to Fix Joy-Con Drift Without Disassembly: step 8, image 3 of 3
    • Insert the Joy-Con back into the Switch to test the Joy-Con.
    • Navigate to System Settings > Controllers and Sensors > Calibrate Control Sticks.
    • Follow the on-screen prompts on your Switch.
Enjoy your Joy-Con being able to work properly again!
27 other people completed this guide.
Weijie Chen
917 Reputation
1 Guide authored
2 Comments
Muchas gracias.
AlmudenaPita - Reply
Process says it requires compressed air then goes on to use contact cleaner instead.
Mike Burr - Reply
Past 24 Hours: 93
Past 7 Days: 533
Past 30 Days: 2,047
All Time: 65,848
