How to Fix Logitech G403 Double Click Issue
  1. How to Fix Logitech G403 Double Click Issue, How to Fix Logitech G403 Double Click Issue: step 1, image 1 of 1
    • Use a prying tool or your hand to take out both sides of the mouse feet.
  2. How to Fix Logitech G403 Double Click Issue: step 2, image 1 of 1
    • Use a precision screwdriver to remove four screws from the mouse.
  3. How to Fix Logitech G403 Double Click Issue: step 3, image 1 of 2 How to Fix Logitech G403 Double Click Issue: step 3, image 2 of 2
    • Slowly open the mouse, and take care not to tear the ribbon cable.
    • Detach the cable connector.
  4. How to Fix Logitech G403 Double Click Issue: step 4, image 1 of 2 How to Fix Logitech G403 Double Click Issue: step 4, image 2 of 2
    • Remove seven screws from the upper cover.
  5. How to Fix Logitech G403 Double Click Issue: step 5, image 1 of 2 How to Fix Logitech G403 Double Click Issue: step 5, image 2 of 2
    • Remove four screws from the mouse.
    • Remove the mouse click cover.
  6. How to Fix Logitech G403 Double Click Issue: step 6, image 1 of 2 How to Fix Logitech G403 Double Click Issue: step 6, image 2 of 2
    • Remove the five screws attached to the mouse click switches.
  7. How to Fix Logitech G403 Double Click Issue: step 7, image 1 of 2 How to Fix Logitech G403 Double Click Issue: step 7, image 2 of 2
    • Open the mouse switch using a prying tool or your hands.
    • Be careful not to lose the white plastic part from the mouse switch.
  8. How to Fix Logitech G403 Double Click Issue: step 8, image 1 of 2 How to Fix Logitech G403 Double Click Issue: step 8, image 2 of 2
    • Find the place where more tension is needed.
    • Use a prying tool or your hand to give more tension to the copper piece, making sure the copper is curved.
10 other people completed this guide.
Jisuk Kang
415 Reputation
1 Guide authored
10 Guide Comments
step 8 made no sense and had to google it
rel - Reply
did you find a video about that? if you could send it pls or if it was some place where talk more about it
Lian López -
Worked!!! I had this problem for years, even stoped playing valorant bacause of that. Thanks
VampireKing - Reply
I could not open these screws :( What are the screwdriver size to open these?
Siim - Reply
Past 24 Hours: 10
Past 7 Days: 77
Past 30 Days: 272
All Time: 35,422
