How to Fix Sticky Keys in a Corsair K70 RGB Mk2 Keyboard
  1. How to Fix Sticky Keys in a Corsair K70 RGB Mk2 Keyboard, How to Fix Sticky Keys in a Corsair K70 RGB Mk2 Keyboard: step 1, image 1 of 1
    • Unplug the keyboard.
  2. How to Fix Sticky Keys in a Corsair K70 RGB Mk2 Keyboard: step 2, image 1 of 2 How to Fix Sticky Keys in a Corsair K70 RGB Mk2 Keyboard: step 2, image 2 of 2
    • Take off all the key caps in the affected area by pulling them off with your fingers.
  3. How to Fix Sticky Keys in a Corsair K70 RGB Mk2 Keyboard: step 3, image 1 of 3 How to Fix Sticky Keys in a Corsair K70 RGB Mk2 Keyboard: step 3, image 2 of 3 How to Fix Sticky Keys in a Corsair K70 RGB Mk2 Keyboard: step 3, image 3 of 3
    • Wipe down the affected areas and keys with sanitizing wipes and isopropyl alcohol.
  4. How to Fix Sticky Keys in a Corsair K70 RGB Mk2 Keyboard: step 4, image 1 of 1
    • Blow dry the affected keys and do not concentrate heat on one spot.
  5. How to Fix Sticky Keys in a Corsair K70 RGB Mk2 Keyboard: step 5, image 1 of 1
    • Dip a toothpick’s tip into sanitizing liquid or isopropyl alcohol.
  6. How to Fix Sticky Keys in a Corsair K70 RGB Mk2 Keyboard: step 6, image 1 of 3 How to Fix Sticky Keys in a Corsair K70 RGB Mk2 Keyboard: step 6, image 2 of 3 How to Fix Sticky Keys in a Corsair K70 RGB Mk2 Keyboard: step 6, image 3 of 3
    • Coat the inside of the walls and press the key down to help spread the liquid.
    • Repeat steps 5-6 two to three times.
  7. How to Fix Sticky Keys in a Corsair K70 RGB Mk2 Keyboard: step 7, image 1 of 2 How to Fix Sticky Keys in a Corsair K70 RGB Mk2 Keyboard: step 7, image 2 of 2
    • Replace the key caps.
Jonathan Joe Mai
169 Reputation
1 Guide authored
2 Comments
I’ve been doing this for multiple days/nights after a tea spill that made 5 keys sticky. I have used isopropyl alcohol with q tips. Blowing into the switches afterword helps also. For me though, this works for a while until the keys dry and become sticky again. I don’t really know what else to do. Anybody got any tips/fixes?
The Idiot Genius - Reply
Try some circuit board cleaner. No guarantees but that might fix it. They usually come with a nozzle so you can really blast it in there as well. If that doesn’t work you’re probably pulling your keyboard apart and replacing the switch.
Ezra - Reply
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 175
All Time: 9,511
