How to Fix Stripped Screw Holes from Cabinet Hinges
  1. How to Fix Stripped Screw Holes from Cabinet Hinges, How to Fix Stripped Screw Holes from Cabinet Hinges: step 1, image 1 of 3 How to Fix Stripped Screw Holes from Cabinet Hinges, How to Fix Stripped Screw Holes from Cabinet Hinges: step 1, image 2 of 3 How to Fix Stripped Screw Holes from Cabinet Hinges, How to Fix Stripped Screw Holes from Cabinet Hinges: step 1, image 3 of 3
    • Use a screwdriver to remove the screws from the stripped holes.
  2. How to Fix Stripped Screw Holes from Cabinet Hinges: step 2, image 1 of 1
    • Take a screw from the cabinet hinge and use it to determine the appropriate size of screw anchor.
  3. How to Fix Stripped Screw Holes from Cabinet Hinges: step 3, image 1 of 2 How to Fix Stripped Screw Holes from Cabinet Hinges: step 3, image 2 of 2
    • Clear the screw holes of any debris.
  4. How to Fix Stripped Screw Holes from Cabinet Hinges: step 4, image 1 of 2 How to Fix Stripped Screw Holes from Cabinet Hinges: step 4, image 2 of 2
    • Place the screw anchors within each of the stripped screw holes.
  5. How to Fix Stripped Screw Holes from Cabinet Hinges: step 5, image 1 of 2 How to Fix Stripped Screw Holes from Cabinet Hinges: step 5, image 2 of 2
    • Secure the screw anchors within the hole by lightly tapping on them with a hammer.
    • Too much force can damage the anchor.
  6. How to Fix Stripped Screw Holes from Cabinet Hinges: step 6, image 1 of 2 How to Fix Stripped Screw Holes from Cabinet Hinges: step 6, image 2 of 2
    • Once the screw anchors are secured in place, align the cabinet hinges with the anchor holes.
    • Top of the anchor must fit tightly in the stripped hole.
  7. How to Fix Stripped Screw Holes from Cabinet Hinges: step 7, image 1 of 3 How to Fix Stripped Screw Holes from Cabinet Hinges: step 7, image 2 of 3 How to Fix Stripped Screw Holes from Cabinet Hinges: step 7, image 3 of 3
    • Use a screwdriver and spin clockwise to screw the nail in place.
  8. How to Fix Stripped Screw Holes from Cabinet Hinges: step 8, image 1 of 1
    • The screws are now secured, and the cabinet will no longer wobble.
Well done!
2 other people completed this guide.
Richmond La
217 Reputation
1 Guide authored
2 Comments
Boutje moertje door de wand is ook stevig
Aad Petersen - Reply
Wat also de gat te groot is. Moet je dan niet eerst gat vullen. Maar wat is handig, lijm of wax?
Nas sai - Reply
Past 24 Hours: 27
Past 7 Days: 151
Past 30 Days: 708
All Time: 23,126
