How to Fix Subwoofer Amplifiers
  1. How to Fix Subwoofer Amplifiers, How to Fix Subwoofer Amplifiers: step 1, image 1 of 1
    • Disconnect the black (negative) cable from the battery to disable the electrical connection.
    • Always disconnect the negative cable before the positive cable.
    • Disconnect the red (positive) cable from the battery to disable the electrical connection.
  2. How to Fix Subwoofer Amplifiers: step 2, image 1 of 1
    • Pull the fuses out and make sure that they were not blown.
  3. How to Fix Subwoofer Amplifiers: step 3, image 1 of 1
    • Undo and remove all wires from the amplifier.
    • This should include the battery wire, ground wire, speaker wires, remote wire from the radio, and sound wires that also come from radio.
    • Remove and check the fuse from the amp to make sure it is not a blown fuse.
  4. How to Fix Subwoofer Amplifiers: step 4, image 1 of 1
    • Strip the wires so they can have a better connection.
    • Twist the exposed copper wiring to make it easier to connect to the amplifier.
  5. How to Fix Subwoofer Amplifiers: step 5, image 1 of 1
    • Replace the wires in their designated slots.
    • Tighten the clamps all the way down.
    • Wiggle and tug on the wires to make sure they are secured nice and tight.
  6. How to Fix Subwoofer Amplifiers: step 6, image 1 of 1
    • Replace the battery wires.
    • The red wire should go to the positive side, and the black wire should go to the negative side.
Finish Line
Luke Turner
154 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 55
All Time: 2,056
