How to Fix Xbox 360 Controller Joystick Drift
  1. How to Fix Xbox 360 Controller Joystick Drift, How to Fix Stick Drift on Xbox 360 Controller: step 1, image 1 of 2 How to Fix Xbox 360 Controller Joystick Drift, How to Fix Stick Drift on Xbox 360 Controller: step 1, image 2 of 2
    • Remove seven screws from the back of the controller using a T8 Torx screwdriver.
  2. How to Fix Xbox 360 Controller Joystick Drift: step 2, image 1 of 2 How to Fix Xbox 360 Controller Joystick Drift: step 2, image 2 of 2
    • Remove the back to see the motherboard.
    • Do this with caution as it could easily be damaged if wires disconnect.
  3. How to Fix Xbox 360 Controller Joystick Drift: step 3, image 1 of 2 How to Fix Xbox 360 Controller Joystick Drift: step 3, image 2 of 2
    • Gently dab a cotton swab with isopropyl or rubbing alcohol to the joystick in a circular motion.
    • Be careful when adding liquid; too much liquid can damage the controller.
  4. How to Fix Xbox 360 Controller Joystick Drift: step 4, image 1 of 2 How to Fix Xbox 360 Controller Joystick Drift: step 4, image 2 of 2
    • Use a blow dryer to dry both the left and right joysticks.
2 other people completed this guide.
Luis Ramirez
162 Reputation
1 Guide authored
2 Comments
This is not a genuine Xbox 360 controller and you truly aren't doing anything at all. You haven't even removed the thumbsticks to service the internals of the sensor assembly lol.
Alexander Dimitrov - Reply
Hi, I did this with a genuine controller and it completely worked for me. I just wiped the metal frames and went round the inside-joystick that I could, with the Q-tip.
ShadowNinja5764 - Reply
Past 24 Hours: 16
Past 7 Days: 262
Past 30 Days: 1,173
All Time: 17,600
