How to Fix a BIC Wite-Out Mini
  1. How to Fix a BIC Wite-Out Mini, How to Fix a BIC Wite-Out Mini: step 1, image 1 of 1
    • Place the dispenser component with the logo facing down, with other components laid out on a clean, flat surface.
  2. How to Fix a BIC Wite-Out Mini: step 2, image 1 of 1
    • Stabilize the small gear with tweezers to prevent further unwinding.
  3. How to Fix a BIC Wite-Out Mini: step 3, image 1 of 3 How to Fix a BIC Wite-Out Mini: step 3, image 2 of 3 How to Fix a BIC Wite-Out Mini: step 3, image 3 of 3
    • Untangle the plastic strip by rotating the large gear in a circular motion, going in the opposite direction of the spiral.
    • Stop once the plastic strip connecting the gears is straight.
  4. How to Fix a BIC Wite-Out Mini: step 4, image 1 of 3 How to Fix a BIC Wite-Out Mini: step 4, image 2 of 3 How to Fix a BIC Wite-Out Mini: step 4, image 3 of 3
    • Feed the plastic strip into the small gear until the white-out strip is visible.
    • Turn the big gear toward the small gear until they are close to each other.
  5. How to Fix a BIC Wite-Out Mini: step 5, image 1 of 1
    • Place gears back into dispenser component with the logo.
    • Place the small gear onto the module closer to the dispensing slot.
    • Place the large gear onto module farthest from the dispensing slot.
  6. How to Fix a BIC Wite-Out Mini: step 6, image 1 of 1
    • Hold the white-out strip with tweezers and pull to wrap the strip around the dispensing slot.
    • Make sure to stabilize the gears.
  7. How to Fix a BIC Wite-Out Mini: step 7, image 1 of 3 How to Fix a BIC Wite-Out Mini: step 7, image 2 of 3 How to Fix a BIC Wite-Out Mini: step 7, image 3 of 3
    • Wrap the black band around both gears.
    • If necessary, stabilize the large gear with tweezers.
    • Wrap the band starting from large gear to small gear.
  8. How to Fix a BIC Wite-Out Mini: step 8, image 1 of 2 How to Fix a BIC Wite-Out Mini: step 8, image 2 of 2
    • Close the device until the side components click closed.
Congrats! You have just successfully repaired your BIC Wite-Out Mini!
Test your BIC Wite-Out Mini to make sure that it works correctly. If it does not work, repeat steps 1-8 and try again!
Lauren Miller
157 Reputation
1 Guide authored
UC Davis, Team 3-1, Andersen Winter 2024 Member of UC Davis, Team 3-1, Andersen Winter 2024
UCD-ANDERSEN-W24S3G1
3 Members
1 Guide authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 53
Past 30 Days: 175
All Time: 2,029
