How to Fix a Bent Key
  1. How to Fix a Bent Key, How to Fix a Bent Key: step 1, image 1 of 1
    • Evaluating the key to determine if it can be repaired. Look for any cracks or breaks in the metal.
    • If cracks are present, the key may be too fragile to repair and might need to be replaced.
    • Identify the direction of the bend: Is the key bent inward or outward? This will guide how you apply force during straightening.
  2. How to Fix a Bent Key: step 2, image 1 of 1
    • If the key is made of hardened steel, gently warm it using a heat source to increase pliability.
    • Avoid overheating to the point of discoloration, which could weaken the metal. Additionally, protective gear, such as cloth or gloves, is best for safety precautions.
  3. How to Fix a Bent Key: step 3, image 1 of 1
    • Use pliers to carefully bend the key back into shape. Apply slow, gentle pressure to avoid over-correcting or snapping the metal.
    • For minor bends, a light push may suffice. For larger bends, work incrementally, checking the alignment frequently.
  4. How to Fix a Bent Key: step 4, image 1 of 2 How to Fix a Bent Key: step 4, image 2 of 2
    • For keys with significant bends, place the key in a vise between two soft materials (e.g., cloth or wood) to prevent scratches.
    • Tighten the vise gradually to press the key flat.
  5. How to Fix a Bent Key: step 5, image 1 of 1
    • After straightening, closely examine the key.
    • Check for any cracks. Test its flexibility by gently bending it in the opposite direction to ensure it is sturdy enough for reuse.
  6. How to Fix a Bent Key: step 6, image 1 of 1
    • Once the key has been straightened, test it in the lock to ensure that it functions properly.
    • Verify the alignment by turning the key, ensuring it works as intended and that the teeth are not bent.
    • Retest multiple times to confirm the repair is effective and the key is reliable for regular use.
Finish Line
Essence Bailey
133 Reputation
1 Guide authored
UC Davis, Team 2-4, Vidal-Chiesa Fall 2024 Member of UC Davis, Team 2-4, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S2G4
3 Members
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 82
All Time: 1,137
