How to Fix a Broken Ceramic Vase
  1. How to Fix a Broken Ceramic Vase, How to Fix a Broken Ceramic Vase: step 1, image 1 of 1
    • Examine the damage to the vase. Determine how large the cracks and chips are.
    • Smaller cracks can be fixed with a ceramic adhesive, while larger cracks may require putty.
  2. How to Fix a Broken Ceramic Vase: step 2, image 1 of 1
    • Sand the broken edges and cracked pieces on the vase with a sander block.
  3. How to Fix a Broken Ceramic Vase: step 3, image 1 of 2 How to Fix a Broken Ceramic Vase: step 3, image 2 of 2
    • Apply ceramic adhesive to the broken pieces and press them together for two minutes.
  4. How to Fix a Broken Ceramic Vase: step 4, image 1 of 1
    • Secure masking tape over the cracks and let the vase dry for 3 hours.
  5. How to Fix a Broken Ceramic Vase: step 5, image 1 of 1
    • After the vase dries, clean the areas with a cloth where chunks of ceramic are missing.
  6. How to Fix a Broken Ceramic Vase: step 6, image 1 of 2 How to Fix a Broken Ceramic Vase: step 6, image 2 of 2
    • Use a chisel scraper to fill in the missing areas with putty and allow it to dry completely.
  7. How to Fix a Broken Ceramic Vase: step 7, image 1 of 1
    • Select a paint that matches the vase and use a soft paintbrush to paint the dry putty wall.
  8. How to Fix a Broken Ceramic Vase: step 8, image 1 of 1
    • Let the paint dry for one hour on the vase and your repair is finished.
Finish Line
0 Comments
Past 24 Hours: 1
Past 7 Days: 23
Past 30 Days: 108
All Time: 1,471
