How to Fix a Broken Loop in a Backpack
  1. How to Fix a Broken Loop in a Backpack, Locate the repair area: step 1, image 1 of 2 How to Fix a Broken Loop in a Backpack, Locate the repair area: step 1, image 2 of 2
    • Identify the loop that needs to be repaired.
  2. How to Fix a Broken Loop in a Backpack, Clean the area: step 2, image 1 of 2 How to Fix a Broken Loop in a Backpack, Clean the area: step 2, image 2 of 2
    • Use a seam ripper and a pair of scissors to completely remove the loop and get rid of any loose thread.
    • Tip: Once you have removed the loop, make sure you leave a space in the seam area to reinsert it later.
  3. How to Fix a Broken Loop in a Backpack, Start stitching: step 3, image 1 of 3 How to Fix a Broken Loop in a Backpack, Start stitching: step 3, image 2 of 3 How to Fix a Broken Loop in a Backpack, Start stitching: step 3, image 3 of 3
    • Once you have removed the broken loop, stitch both ends together using a sewing machine.
  4. How to Fix a Broken Loop in a Backpack, Set the loop in place: step 4, image 1 of 3 How to Fix a Broken Loop in a Backpack, Set the loop in place: step 4, image 2 of 3 How to Fix a Broken Loop in a Backpack, Set the loop in place: step 4, image 3 of 3
    • Introduce the stitched loop into the seam hole and hold it together with both hands.
  5. How to Fix a Broken Loop in a Backpack, Stitch the loop in place: step 5, image 1 of 3 How to Fix a Broken Loop in a Backpack, Stitch the loop in place: step 5, image 2 of 3 How to Fix a Broken Loop in a Backpack, Stitch the loop in place: step 5, image 3 of 3
    • Following the last step, keep holding together the loop with both hands and gently place it on the sewing machine and start stitching.
    • Use a pair of scissors to clean the area and cut any loose threads.
  6. How to Fix a Broken Loop in a Backpack, Finished and ready!: step 6, image 1 of 3 How to Fix a Broken Loop in a Backpack, Finished and ready!: step 6, image 2 of 3 How to Fix a Broken Loop in a Backpack, Finished and ready!: step 6, image 3 of 3
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Ben Blischke
10,230 Reputation
66 Guides authored
INTERSPORT Member of INTERSPORT
Community
25 Members
169 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 19
All Time: 309
