How to Fix a Broken Wig
  1. How to Fix a Broken Wig, How to Fix a Broken Wig: step 1, image 1 of 2 How to Fix a Broken Wig, How to Fix a Broken Wig: step 1, image 2 of 2
    • Brush out the wig with a comb. Use a brush if the wig is severely tangled.
    • Do not brush aggressively as you may tear out more pieces of the wig.
  2. How to Fix a Broken Wig: step 2, image 1 of 3 How to Fix a Broken Wig: step 2, image 2 of 3 How to Fix a Broken Wig: step 2, image 3 of 3
    • Lay out the weft so it is not in a clump.
    • Comb out the weft so it is not tangled.
  3. How to Fix a Broken Wig: step 3, image 1 of 3 How to Fix a Broken Wig: step 3, image 2 of 3 How to Fix a Broken Wig: step 3, image 3 of 3
    • Mount the wig on somewhere secure.
    • Clip up the hair out of the way of the damaged spot with hair clips.
  4. How to Fix a Broken Wig: step 4, image 1 of 2 How to Fix a Broken Wig: step 4, image 2 of 2
    • Line up wefts where you want to fill the damaged spot.
  5. How to Fix a Broken Wig: step 5, image 1 of 3 How to Fix a Broken Wig: step 5, image 2 of 3 How to Fix a Broken Wig: step 5, image 3 of 3
    • Pin the lined up wefts in place with the pins so they don’t move around while working.
    • Use caution when working with pins and needles so you do not poke yourself.
  6. How to Fix a Broken Wig: step 6, image 1 of 2 How to Fix a Broken Wig: step 6, image 2 of 2
    • Thread a needle with a long strand of thread.
    • Double it over by pulling the needle to the middle of the thread, then bring both ends together to knot them.
  7. How to Fix a Broken Wig: step 7, image 1 of 3 How to Fix a Broken Wig: step 7, image 2 of 3 How to Fix a Broken Wig: step 7, image 3 of 3
    • Sew the weft in at each of the non-elastic bands of the wig in the damaged area.
    • An overhand stitch (also called a whip stitch) is easy and works well for this fix.
    • Be sure to tie off any loose ends after you are done stitching.
    • If you need help with the stitch, here is a helpful link with instructions.
  8. How to Fix a Broken Wig: step 8, image 1 of 3 How to Fix a Broken Wig: step 8, image 2 of 3 How to Fix a Broken Wig: step 8, image 3 of 3
    • Take out the pins and check to see if there is still damage and another weft is needed.
    • If the damage is still noticeable, repeat steps 1-8 with another weft. If not, you are ready to use your wig again!
  9. How to Fix a Broken Wig: step 9, image 1 of 2 How to Fix a Broken Wig: step 9, image 2 of 2
    • With a completed wig, you are ready to shine your best out to the world.
Reid Dounias
172 Reputation
1 Guide authored
UC Davis, Team S2-G3, Bender Fall 2018 Member of UC Davis, Team S2-G3, Bender Fall 2018
UCD-BENDER-F18S2G3
2 Members
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 935
