How to Fix a Carabiner
  1. How to Fix a Carabiner, How to Fix a Carabiner: step 1, image 1 of 1
    • Position the carabiner so that the gate is pushed forward past the nose and the latch is hanging out.
  2. How to Fix a Carabiner: step 2, image 1 of 1
    • Position the pliers between the rivet pin.
    • The rivet pin is a flat rectangle metal piece poking out of the hinges.
  3. How to Fix a Carabiner: step 3, image 1 of 1
    • Gently but firmly squeeze the rivet pin behind the hinge.
  4. How to Fix a Carabiner: step 4, image 1 of 2 How to Fix a Carabiner: step 4, image 2 of 2
    • Push the gate back, so that it is behind the nose.
    • Be sure to push the gate slowly and carefully, to avoid unnecessary jerking around, which could potentially break the carabiner further.
  5. How to Fix a Carabiner: step 5, image 1 of 1
    • Position the gate back to the original position behind the nose.
  6. How to Fix a Carabiner: step 6, image 1 of 1
    • The gate should now snap back into position securely. If it does not, repeat the process.
    • Be sure that the rivet pin was not bent or broken in the act of guiding the gate back to its original position.
Finish Line
5 other people completed this guide.
2 Guide Comments
Thank you for tutorial I was autism and bent it.
Vehicular manslaughter - Reply Share
Was gonna throw the old one away but this helped. Good as new now, thanks!
Maksim Krotov - Reply Share
Past 24 Hours: 19
Past 7 Days: 105
Past 30 Days: 468
All Time: 31,277
