How to Fix a Crack in a Hollow Wood Door
  1. How to Fix a Crack in a Hollow Wood Door, How to Fix a Crack in a Hollow Wood Door: step 1, image 1 of 2 How to Fix a Crack in a Hollow Wood Door, How to Fix a Crack in a Hollow Wood Door: step 1, image 2 of 2
    • Clean and dust the affected area with a paper towel, rag, or brush.
  2. How to Fix a Crack in a Hollow Wood Door: step 2, image 1 of 1
    • Sand the affected area with a 60/80 grit sanding sponge.
    • Any type of sand paper or sanding sponge will work on wood surfaces.
    • It is recommended to place newspaper under the door to keep the sand/dust contained.
  3. How to Fix a Crack in a Hollow Wood Door: step 3, image 1 of 1
    • Remove any sand/dust with a paper towel.
    • It is recommend to use gloves to prevent any minor splinters.
    • It is also recommended to use a face mask to prevent inhaling any dust/sand.
  4. How to Fix a Crack in a Hollow Wood Door: step 4, image 1 of 1
    • Use putty knife to apply body filler until an even layer is formed.
    • Start with a small amount and then add more if needed.
    • A smaller putty knife allows for easier application in creases and folds.
  5. How to Fix a Crack in a Hollow Wood Door: step 5, image 1 of 1
    • Remove any excess body filler with putty knife
    • Its okay if the surface is uneven, you will use sandpaper to smooth the surface in a later step.
  6. How to Fix a Crack in a Hollow Wood Door: step 6, image 1 of 1
    • Allow to dry (or use a blow dryer for lesser wait time).
    • More expensive brands of body filler will dry faster.
  7. How to Fix a Crack in a Hollow Wood Door: step 7, image 1 of 2 How to Fix a Crack in a Hollow Wood Door: step 7, image 2 of 2
    • Gently sand the surface.
    • Gloves and a face mask are highly recommended but not required for this step.
    • Newspaper is also recommended to contain any sand/dust.
    • Reapply body filler, allow to dry, and re-sand if surface remains uneven.
  8. How to Fix a Crack in a Hollow Wood Door: step 8, image 1 of 1
    • Use a similar toned paint to paint the area if any discoloration exists.
    • Wood paint is ideal for wood doors.
  9. How to Fix a Crack in a Hollow Wood Door: step 9, image 1 of 1
    • Allow to dry.
    • Your door should now look neutral and clean.
    • A blow dryer is recommended for faster drying.
3 other people completed this guide.
Lea Thomas
250 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 22
Past 7 Days: 146
Past 30 Days: 700
All Time: 144,501
