How to Fix a Cracked Fingernail
  1. How to Fix a Cracked Fingernail, How to Fix a Cracked Fingernail: step 1, image 1 of 2 How to Fix a Cracked Fingernail, How to Fix a Cracked Fingernail: step 1, image 2 of 2
    • Examine the crack and clean off as much nail polish and grime as possible.
  2. How to Fix a Cracked Fingernail: step 2, image 1 of 2 How to Fix a Cracked Fingernail: step 2, image 2 of 2
    • Cut out a small rectangle from a teabag.
    • It should be big enough to cover the crack.
  3. How to Fix a Cracked Fingernail: step 3, image 1 of 1
    • Add a drop of glue to the crack.
  4. How to Fix a Cracked Fingernail: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Place the cut out teabag on top of the glue to cover the whole crack.
    • Gently press down on the rectangle with tweezers to make it flat on the nail.
  5. How to Fix a Cracked Fingernail: step 5, image 1 of 2 How to Fix a Cracked Fingernail: step 5, image 2 of 2
    • Cut off the excess teabag after the glue is dry.
    • Apply more glue (after trimming) to cover the teabag, making sure it's all coated and flat on the nail surface.
  6. How to Fix a Cracked Fingernail: step 6, image 1 of 2 How to Fix a Cracked Fingernail: step 6, image 2 of 2
    • After the glue is dry, use a nail filer to shape the nail and a nail buffer to smooth out the top surface of the nail.
  7. How to Fix a Cracked Fingernail: step 7, image 1 of 3 How to Fix a Cracked Fingernail: step 7, image 2 of 3 How to Fix a Cracked Fingernail: step 7, image 3 of 3
    • After you finish shaping and buffing the nail, wash your hands in lukewarm water.
    • The nail should feel smooth and the crack should be sealed.
    • For extra reinforcement, you can paint your nails or add only a topcoat (clear) nail polish. Painting your nails is completely optional.
This fix can help you keep your nail from getting caught on things if the crack is too low to cut off the excess. Try to avoid soaking the nail in water for too long since it can make the nail softer and reduce the effectiveness of the adhesion on the nail. Please seek medical attention if the crack is serious and is causing a lot of pain and/or discoloration.
Tammy Chung
145 Reputation
1 Guide authored
4 Comments
Thanks for sharing. I've broken my nail just yesterday:(
goddyhevil - Reply
Thank you for the article. The information might be useful next time I break my nail.
sentinmorty - Reply
Thanks for the detailed guide! I didn’t know it was that easy to do it alone. Every time my ail breaks, I just ask my friend to fix it somehow. She studies at nail master's college https://www.nwcollege.edu/programs/nail-... and knows how to do it. She has already bought some equipment and materials for a manicure; I’m usually her model. To tell the truce, she must be very talented because the nails done by her are better than those I pay a lot for. However, it’s hard to get to her place (she lives in another town), which is the only disadvantage of our friendship. I like having a friend who is a nail master because it saves me a lot.
jenniferelder - Reply
this is awsome i have very long nails and i really dont want to trim them off so this gave alot of advise
Bibi Sara - Reply
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 35
All Time: 1,120
