How to Fix a Hole in Leggings by Hand Sewing
  1. How to Fix a Hole in Leggings by Hand Sewing, How to Fix a Hole in Leggings by Hand Sewing: step 1, image 1 of 3 How to Fix a Hole in Leggings by Hand Sewing, How to Fix a Hole in Leggings by Hand Sewing: step 1, image 2 of 3 How to Fix a Hole in Leggings by Hand Sewing, How to Fix a Hole in Leggings by Hand Sewing: step 1, image 3 of 3
    • Use scissors to cut a piece of thread that is the color of your leggings at least 12 inches long.
  2. How to Fix a Hole in Leggings by Hand Sewing: step 2, image 1 of 1
    • Mishandling of the needle could result in minor or moderate injury.
    • Thread the needle by running the piece of thread through the eye, or opening, of the needle.
  3. How to Fix a Hole in Leggings by Hand Sewing: step 3, image 1 of 1
    • Pull the thread through the needle until there are two equal halves of thread.
    • Tie a knot with the ends of the thread.
  4. How to Fix a Hole in Leggings by Hand Sewing: step 4, image 1 of 1
    • Turn the leggings inside out.
    • This is so the sewing will be on the inside of the leggings.
  5. How to Fix a Hole in Leggings by Hand Sewing: step 5, image 1 of 1
    • Smooth out the fabric around the hole.
  6. How to Fix a Hole in Leggings by Hand Sewing: step 6, image 1 of 1
    • Pinch the fabric together.
    • Begin your stitch on one end of the hole.
  7. How to Fix a Hole in Leggings by Hand Sewing: step 7, image 1 of 1
    • Use short stitches so that the thread will not break easily.
    • Make sure the hole is completely included in the stitches.
  8. How to Fix a Hole in Leggings by Hand Sewing: step 8, image 1 of 1
    • Tie a knot using the tied ends of the thread (at the beginning of the hole) and the thread still attached to the needle (at the end of the hole).
    • Make sure the knot is large enough so it doesn't slip through the stitches.
  9. How to Fix a Hole in Leggings by Hand Sewing: step 9, image 1 of 1
    • Cut the loose thread above the new knot with scissors.
Finish Line
2 other people completed this guide.
0 Comments
Past 24 Hours: 20
Past 7 Days: 132
Past 30 Days: 653
All Time: 42,530
