You're viewing a previously published version of this guide.  View latest version
Older Newer
How to Fix a Hole in a Pant Pocket
Dolapo Ajose
Dolapo Ajose and one other contributor
Last updated on December 21, 2021
15 minutes
Easy
Introduction
Go to step 1
If your pant pocket has been ripped- damaged, or has a hole in it, use this guide to fix the hole in the pocket.
The pocket in your pant help keep your important possessions like phone, key. A ripped pocket will allow all your possessions to fall get damaged and can lead to loss.
Before using this guide make sure you have some knowledge of sewing with a double stitch method.
Step 4 requires you to insert pins in the traced area you want to sew. This would help create holes. From there you would need to sew the ripped portion using a needle and thread.
Before beginning, make sure to flip the pocket in and out.
  1. How to Fix a Hole in a Pant Pocket: step 2, image 1 of 2 How to Fix a Hole in a Pant Pocket: step 2, image 2 of 2
    • Carefully align the ripped part of the pocket together.
  2. How to Fix a Hole in a Pant Pocket: step 3, image 1 of 3 How to Fix a Hole in a Pant Pocket: step 3, image 2 of 3 How to Fix a Hole in a Pant Pocket: step 3, image 3 of 3
    • Put a sewing pin into a stable piece of fabric to make a hole.
    • Carefully remove the pins.
  3. How to Fix a Hole in a Pant Pocket: step 5, image 1 of 3 How to Fix a Hole in a Pant Pocket: step 5, image 2 of 3 How to Fix a Hole in a Pant Pocket: step 5, image 3 of 3
    • Carefully insert the a threaded sewing needle into the hole you created at one end of the tear.
    • Sew along the length of the tear, joining the two pieces of fabric together.
    • Be very careful when using needle as the point can be very sharp and lead to injury.
  4. How to Fix a Hole in a Pant Pocket: step 6, image 1 of 2 How to Fix a Hole in a Pant Pocket: step 6, image 2 of 2
    • Sew around the ending part a couple times to prevent it from loosen again.
  5. How to Fix a Hole in a Pant Pocket: step 7, image 1 of 1
    • Tie a few knots on both ends of the closed tear to ensure the stitching doesn't come loose.
    • Carefully cut the remaining thread.
    • Be very careful while cutting the thread to avoid cutting some part of the material also.
Dolapo Ajose
244 Reputation
1 Guide authored
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 58
All Time: 4,776
