How to Fix a Jammed Janome 3160QDC Needle
  1. How to Fix a Jammed Janome 3160QDC Needle, How to Fix a Jammed Janome 3160QDC Needle: step 1, image 1 of 3 How to Fix a Jammed Janome 3160QDC Needle, How to Fix a Jammed Janome 3160QDC Needle: step 1, image 2 of 3 How to Fix a Jammed Janome 3160QDC Needle, How to Fix a Jammed Janome 3160QDC Needle: step 1, image 3 of 3
    • If the needle gets stuck while sewing a stitch, stop sewing.
    • Turn the knob on the side of your machine to manually lift the needle out of the fabric.
  2. How to Fix a Jammed Janome 3160QDC Needle: step 2, image 1 of 3 How to Fix a Jammed Janome 3160QDC Needle: step 2, image 2 of 3 How to Fix a Jammed Janome 3160QDC Needle: step 2, image 3 of 3
    • Once the needle is out of the fabric, use the block lever to life the plastic foot press from the fabric as well.
  3. How to Fix a Jammed Janome 3160QDC Needle: step 3, image 1 of 2 How to Fix a Jammed Janome 3160QDC Needle: step 3, image 2 of 2
    • Once plastic foot press is lifted from the fabric pull the fabric away from the machine and cut the thread.
  4. How to Fix a Jammed Janome 3160QDC Needle: step 4, image 1 of 3 How to Fix a Jammed Janome 3160QDC Needle: step 4, image 2 of 3 How to Fix a Jammed Janome 3160QDC Needle: step 4, image 3 of 3
    • Open the bobbin holder and remove the bobbin making sure to also remove the thread from the machine.
  5. How to Fix a Jammed Janome 3160QDC Needle: step 5, image 1 of 3 How to Fix a Jammed Janome 3160QDC Needle: step 5, image 2 of 3 How to Fix a Jammed Janome 3160QDC Needle: step 5, image 3 of 3
    • using the metal knob on the right side of the needle, unscrew and remove the needle. Once the needle has been removed inspect it for damages. If there is no damage reinsert the same needle. If there are damages replace the needle.
  6. How to Fix a Jammed Janome 3160QDC Needle: step 6, image 1 of 2 How to Fix a Jammed Janome 3160QDC Needle: step 6, image 2 of 2
    • Once the needle is back in the sewing machine, thread it and thread the bobbin. From here you are able to begin sewing again.
Abby Karin Palko
133 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 161
