How to Fix a Jammed Mahjong Table
  1. How to Fix a Jammed Mahjong Table, How to Fix a Jammed Mahjong Table: step 1, image 1 of 1
    • Unplug the mahjong table.
  2. How to Fix a Jammed Mahjong Table: step 2, image 1 of 1
    • Remove the outer edge of the mahjong table and set it aside.
  3. How to Fix a Jammed Mahjong Table: step 3, image 1 of 2 How to Fix a Jammed Mahjong Table: step 3, image 2 of 2
    • Lift the top frame up, exposing the inside.
  4. How to Fix a Jammed Mahjong Table: step 4, image 1 of 3 How to Fix a Jammed Mahjong Table: step 4, image 2 of 3 How to Fix a Jammed Mahjong Table: step 4, image 3 of 3
    • Be cautious when putting your hands inside due to sharp parts: gloves and tweezer recommended.
    • Remove the long (green) platform cover of the jammed platform and set it aside to expose the opening of the platform.
    • Carefully remove the foreign object from the opening of the platform.
  5. How to Fix a Jammed Mahjong Table: step 5, image 1 of 1
    • After removing the foreign object, remove the rest of the tiles and set them aside.
  6. How to Fix a Jammed Mahjong Table: step 6, image 1 of 2 How to Fix a Jammed Mahjong Table: step 6, image 2 of 2
    • Reassemble all the components and turn on the power.
  7. How to Fix a Jammed Mahjong Table: step 7, image 1 of 1
    • Press the center control panel to expose the center hole.
    • Push all the tiles in the center hole to ensure the machine properly builds the "wall" for play.
Finish Line
2 other people completed this guide.
ShuRen
175 Reputation
1 Guide authored
UC Davis, Team 1-4, Whithaus Spring 2024 Member of UC Davis, Team 1-4, Whithaus Spring 2024
UCD-WHITHAUS-S24S1G4
3 Members
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 35
Past 30 Days: 120
All Time: 1,521
