How to Fix a Loose Cookware Lid Handle
  1. How to Fix a Loose Cookware Lid Handle, How to Fix a Loose Cookware Lid Handle: step 1, image 1 of 1
    • Wash the glass of the lid with hot water.
    • Be sure to scrub underneath and around the handle.
  2. How to Fix a Loose Cookware Lid Handle: step 2, image 1 of 1
    • Clean the glass lid with a dry piece of cloth.
    • Make sure to especially clean below and around the handle.
  3. How to Fix a Loose Cookware Lid Handle: step 3, image 1 of 2 How to Fix a Loose Cookware Lid Handle: step 3, image 2 of 2
    • Unscrew the handle from the lid and remove the screw and washer.
  4. How to Fix a Loose Cookware Lid Handle: step 4, image 1 of 2 How to Fix a Loose Cookware Lid Handle: step 4, image 2 of 2
    • Clean the hole of the handle with a drop of vinegar and baking soda.
    • Firmly apply the drop of vinegar and baking soda below and underneath the hole, which will clear the surface of any dirt.
  5. How to Fix a Loose Cookware Lid Handle: step 5, image 1 of 3 How to Fix a Loose Cookware Lid Handle: step 5, image 2 of 3 How to Fix a Loose Cookware Lid Handle: step 5, image 3 of 3
    • Clean the screw and washer with a drop of vinegar and baking soda.
    • Allow the parts to dry for about 1-2 minutes.
  6. How to Fix a Loose Cookware Lid Handle: step 6, image 1 of 2 How to Fix a Loose Cookware Lid Handle: step 6, image 2 of 2
    • Apply super glue around the hole of the handle.
    • Be cautious when using super glue that you don't spill it over the bigger glass surface.
  7. How to Fix a Loose Cookware Lid Handle: step 7, image 1 of 3 How to Fix a Loose Cookware Lid Handle: step 7, image 2 of 3 How to Fix a Loose Cookware Lid Handle: step 7, image 3 of 3
    • Quickly install the handle back onto the lid using the screw and washer.
    • Be careful not to touch the glue with your fingers.
    • Once again keep it dry for about 4-5 minutes.
    • The loose handle on your glass lid is fixed and ready to use.
Dinuk Warnapura
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 60
All Time: 2,988
