How to Fix a Razer Naga Trinity Click Button
  1. How to Fix a Razer Naga Trinity Click Button, How to Fix a Razer Naga Trinity Click Button: step 1, image 1 of 3 How to Fix a Razer Naga Trinity Click Button, How to Fix a Razer Naga Trinity Click Button: step 1, image 2 of 3 How to Fix a Razer Naga Trinity Click Button, How to Fix a Razer Naga Trinity Click Button: step 1, image 3 of 3
    • Remove the three pads from the bottom of the mouse.
    • Remove the four screws beneath the pads using a JIS #1 screwdriver.
  2. How to Fix a Razer Naga Trinity Click Button: step 2, image 1 of 2 How to Fix a Razer Naga Trinity Click Button: step 2, image 2 of 2
    • Press the top of mouse and pull back to disconnect the mouse shell.
    • Pull out the cord that connects the RGB button.
  3. How to Fix a Razer Naga Trinity Click Button: step 3, image 1 of 2 How to Fix a Razer Naga Trinity Click Button: step 3, image 2 of 2
    • Remove the right shell.
    • Disconnect the cable connecting the left shell to the mouse.
    • Remove the left shell.
  4. How to Fix a Razer Naga Trinity Click Button: step 4, image 1 of 1
    • Use a safety pin to unlatch the clicker buttons.
  5. How to Fix a Razer Naga Trinity Click Button: step 5, image 1 of 2 How to Fix a Razer Naga Trinity Click Button: step 5, image 2 of 2
    • Insert the open safety pin to lift one side latch slightly.
    • Do not open the whole part.
    • Repeat for the other side.
  6. How to Fix a Razer Naga Trinity Click Button: step 6, image 1 of 3 How to Fix a Razer Naga Trinity Click Button: step 6, image 2 of 3 How to Fix a Razer Naga Trinity Click Button: step 6, image 3 of 3
    • Remove the clicker and white pin.
    • Gently press the middle part of the copper sheet until it unhooks itself.
    • Pull the bended part of the copper sheet back.
  7. How to Fix a Razer Naga Trinity Click Button: step 7, image 1 of 1
    • Reassemble the copper sheet with the white pin seated properly.
    • Push the spring down into its place using a spudger.
    • You will hear a click sound if you successfully assemble it.
4 other people completed this guide.
Haoran Ke
283 Reputation
1 Guide authored
1 Guide Comment
On the latest version of the mouse, the clicker button can no longer be opened...
Jérémie PLAYOUT - Reply
Past 24 Hours: 17
Past 7 Days: 75
Past 30 Days: 281
All Time: 14,221
