How to Fix a Ripped Stuffed Animal
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. How to Fix a Ripped Stuffed Animal, How to Fix a Ripped Stuffed Animal: step 1, image 1 of 3 How to Fix a Ripped Stuffed Animal, How to Fix a Ripped Stuffed Animal: step 1, image 2 of 3 How to Fix a Ripped Stuffed Animal, How to Fix a Ripped Stuffed Animal: step 1, image 3 of 3
    • Use Polyester Fiberfill stuffing to fill the stuffed bear via rip. Add more stuffing for a firmer toy.
    • Do not overfill the toy, or it may rip again.
  2. How to Fix a Ripped Stuffed Animal: step 2, image 1 of 1
    • Insert a thread through the eye of the needle (the hole) and tie it tightly to the needle.
  3. How to Fix a Ripped Stuffed Animal: step 3, image 1 of 1
    • Make a knot at the loose end of the thread.
    • This is so that the thread doesn't slip through the cloth while sewing up the bear.
  4. How to Fix a Ripped Stuffed Animal: step 4, image 1 of 3 How to Fix a Ripped Stuffed Animal: step 4, image 2 of 3 How to Fix a Ripped Stuffed Animal: step 4, image 3 of 3
    • Push needle through the end of the rip.
    • Continue along the seam, putting the needle through both sides of the rip to create a stitch.
  5. How to Fix a Ripped Stuffed Animal: step 5, image 1 of 2 How to Fix a Ripped Stuffed Animal: step 5, image 2 of 2
    • After the rip is sewn shut, tie the end of the thread by creating a knot
    • Create the knot by wrapping the thread around the needle several times Then pull the thread through to secure the knot at the base.
    • Once is enough, but for more security, you can repeat this step twice.
  6. How to Fix a Ripped Stuffed Animal: step 6, image 1 of 3 How to Fix a Ripped Stuffed Animal: step 6, image 2 of 3 How to Fix a Ripped Stuffed Animal: step 6, image 3 of 3
    • Cut any excess thread and you're done!
    • Enjoy your repaired stuffed bear!
Megan Nash
108 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 26
All Time: 243
