How to Fix a Small Hole in a Sock
  1. How to Fix a Small Hole in a Sock, How to Fix a Small Hole in a Sock: step 1, image 1 of 3 How to Fix a Small Hole in a Sock, How to Fix a Small Hole in a Sock: step 1, image 2 of 3 How to Fix a Small Hole in a Sock, How to Fix a Small Hole in a Sock: step 1, image 3 of 3
    • Place one end of your thread through the hole of the needle.
    • Wet the end of your thread to make it easier to go through the hole.
    • Pull your thread all the way through and match the ends of the thread together.
    • Tie a knot with the ends of your thread.
    • The needle is sharp. Handle it carefully to prevent poking your fingers or hand.
  2. How to Fix a Small Hole in a Sock: step 2, image 1 of 2 How to Fix a Small Hole in a Sock: step 2, image 2 of 2
    • Insert your tennis ball into the sock until it is lined up with the hole in your sock.
  3. How to Fix a Small Hole in a Sock: step 3, image 1 of 3 How to Fix a Small Hole in a Sock: step 3, image 2 of 3 How to Fix a Small Hole in a Sock: step 3, image 3 of 3
    • Insert your needle into the inside of the sock at the edge of the hole no more than half a centimeter away from the edge.
    • Pull the needle all the way through.
    • If the tail of your thread is too long, trim the excess.
  4. How to Fix a Small Hole in a Sock: step 4, image 1 of 1
    • Insert your needle next to and below where the first insert was.
    • Pull your needle all the way through to create your first stitch.
  5. How to Fix a Small Hole in a Sock: step 5, image 1 of 2 How to Fix a Small Hole in a Sock: step 5, image 2 of 2
    • Insert your needle in the opposite side of the hole and pull to create another stitch.
    • Repeat this step, crisscrossing your stitches until you reach the end of the hole.
    • Keep your stitches loose. You will tighten them at the end.
  6. How to Fix a Small Hole in a Sock: step 6, image 1 of 3 How to Fix a Small Hole in a Sock: step 6, image 2 of 3 How to Fix a Small Hole in a Sock: step 6, image 3 of 3
    • Once you reach the end of the hole, carefully pull on your thread to tighten the stitches together.
  7. How to Fix a Small Hole in a Sock: step 7, image 1 of 2 How to Fix a Small Hole in a Sock: step 7, image 2 of 2
    • To close off the stitch, insert your needle back under all of your stitches and pull out your needle at the top of the repair.
    • Pull your needle through, but not all the way, to create a small loop.
  8. How to Fix a Small Hole in a Sock: step 8, image 1 of 2 How to Fix a Small Hole in a Sock: step 8, image 2 of 2
    • Insert the needle through the small loop.
    • Pull your needle until the loop disappears.
  9. How to Fix a Small Hole in a Sock: step 9, image 1 of 2 How to Fix a Small Hole in a Sock: step 9, image 2 of 2
    • To create a final stitch, insert your needle back under all of your stitches.
    • Pull the thread all the way through.
  10. How to Fix a Small Hole in a Sock: step 10, image 1 of 3 How to Fix a Small Hole in a Sock: step 10, image 2 of 3 How to Fix a Small Hole in a Sock: step 10, image 3 of 3
    • Trim off the excess thread.
    • Remove the tennis ball from your sock.
Finish Line
3 other people completed this guide.
Yuchen Xu
223 Reputation
1 Guide authored
UC Davis, Team 3-2, Andersen Winter 2023 Member of UC Davis, Team 3-2, Andersen Winter 2023
UCD-ANDERSEN-W23S3G2
3 Members
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 54
All Time: 1,201
