How to Fix a Stretched or Loose Canvas
  1. How to Fix a Stretched or Loose Canvas, How to Fix a Stretched or Loose Canvas: step 1, image 1 of 2 How to Fix a Stretched or Loose Canvas, How to Fix a Stretched or Loose Canvas: step 1, image 2 of 2
    • Fill a spray bottle with water at room temperature.
    • In case that you do not have a spray bottle you can use a dishcloth and moisten it.
  2. How to Fix a Stretched or Loose Canvas: step 2, image 1 of 3 How to Fix a Stretched or Loose Canvas: step 2, image 2 of 3 How to Fix a Stretched or Loose Canvas: step 2, image 3 of 3
    • Close the spray bottle tightly.
    • Turn the nozzle to spray.
  3. How to Fix a Stretched or Loose Canvas: step 3, image 1 of 2 How to Fix a Stretched or Loose Canvas: step 3, image 2 of 2
    • Put a towel on a flat surface and lay the canvas face down on the towel.
  4. How to Fix a Stretched or Loose Canvas: step 4, image 1 of 3 How to Fix a Stretched or Loose Canvas: step 4, image 2 of 3 How to Fix a Stretched or Loose Canvas: step 4, image 3 of 3
    • Carefully wet the entire backside of the canvas with the spray, or press water onto the canvas with the dishcloth.
    • Only spray until it is damp. Do not soak the canvas.
    • It does not matter if the canvas is new, old, has unfinished artwork or it is completed.
  5. How to Fix a Stretched or Loose Canvas: step 5, image 1 of 2 How to Fix a Stretched or Loose Canvas: step 5, image 2 of 2
    • Turn on the dryer so warm air comes out.
  6. How to Fix a Stretched or Loose Canvas: step 6, image 1 of 3 How to Fix a Stretched or Loose Canvas: step 6, image 2 of 3 How to Fix a Stretched or Loose Canvas: step 6, image 3 of 3
    • Blow dry the canvas with a hair dryer on warm until it's completely dry.
    • Keep the hair dryer at least 3 to 5 inches away from the canvas.
    • Do not place the hair dryer directly on the canvas. The heat from the hair dryer can burn the canvas.
  7. How to Fix a Stretched or Loose Canvas: step 7, image 1 of 2 How to Fix a Stretched or Loose Canvas: step 7, image 2 of 2
    • Flip the canvas over and check that it is to your liking.
    • Flip the canvas again and double check.
    • Repeat the process again if the canvas is not completely fixed.
If it does not work, you should follow another guide where plaster is used in the canvas.
0 Comments
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 108
All Time: 1,561
