How to Fix a Thrustmaster Eswap X Pro Controller Trigger
  1. How to Fix a Thrustmaster Eswap X Pro Controller Trigger, How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 1, image 1 of 2 How to Fix a Thrustmaster Eswap X Pro Controller Trigger, How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 1, image 2 of 2
    • Flip the controller so the backside is facing up.
    • Flip both of the switches away from the center.
  2. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 2, image 1 of 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 2, image 2 of 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 2, image 3 of 3
    • Flip the controller over so the top is facing up.
    • Pull out both the joystick and the directional pad modules.
  3. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 3, image 1 of 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 3, image 2 of 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 3, image 3 of 3
    • Flip the controller over again so the backside is facing up.
    • Use a spudger to remove five rubber screw covers.
  4. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 4, image 1 of 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 4, image 2 of 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 4, image 3 of 3
    • Use a Phillips #1 screwdriver to remove each of the 4.0 mm exposed screws.
  5. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 5, image 1 of 2 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 5, image 2 of 2
    • Use a Phillips #1 screwdriver to loosen the captive screw and remove the trigger button.
  6. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 6, image 1 of 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 6, image 2 of 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 6, image 3 of 3
    • Rotate the controller 90 degrees.
    • Pull off the magnetic side cover.
  7. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 7, image 1 of 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 7, image 2 of 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 7, image 3 of 3
    • Lift the back cover slightly from where you removed the trigger button.
    • Use a Q-tip dipped with isopropyl alcohol to clean the surrounding area.
    • Additionally, wipe down the top face of the trigger with a Q-tip.
  8. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 8, image 1 of 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 8, image 2 of 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 8, image 3 of 3
    • Reattach the trigger button onto the controller.
    • Use a Phillips #1 screwdriver to tighten the screw securing trigger button.
  9. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 9, image 1 of 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 9, image 2 of 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 9, image 3 of 3
    • Use a Phillips #1 screwdriver to reattach the 4.0 mm screws to the back of the controller.
  10. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 10, image 1 of 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 10, image 2 of 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 10, image 3 of 3
    • Notice that the notches on the rubber covers correspond with the notches on the screw hole.
    • Reattach the rubber covers above the screws.
  11. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 11, image 1 of 1
    • Place the joystick and the directional pad modules back in their respective spots.
  12. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 12, image 1 of 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 12, image 2 of 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 12, image 3 of 3
    • Reattach the magnetic side cover.
    • The controller is fixed!
Laurence Chan
205 Reputation
1 Guide authored
UC Davis, Team 2-3, Morris Winter 2023 Member of UC Davis, Team 2-3, Morris Winter 2023
UCD-MORRIS-W23S2G3
2 Members
1 Guide authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 36
Past 30 Days: 136
All Time: 2,109
