How to Fix a Wobbly Hydraulic Barber Chair
  1. How to Fix a Wobbly Hydraulic Barber Chair, How to Fix a Wobbly Hydraulic Barber Chair: step 1, image 1 of 2 How to Fix a Wobbly Hydraulic Barber Chair, How to Fix a Wobbly Hydraulic Barber Chair: step 1, image 2 of 2
    • The issue with the barber chair is located at the base, where the screws have come loose.
  2. How to Fix a Wobbly Hydraulic Barber Chair: step 2, image 1 of 2 How to Fix a Wobbly Hydraulic Barber Chair: step 2, image 2 of 2
    • Use your foot to repeatedly pump the hydraulic height-adjustment pedal under the chair until the chair reaches max height.
    • While holding the pedal down with your foot, grab both arm rests and pull the chair upwards.
  3. How to Fix a Wobbly Hydraulic Barber Chair: step 3, image 1 of 1
    • Lift the base-ring off the base to reveal the holes for the screws.
  4. How to Fix a Wobbly Hydraulic Barber Chair: step 4, image 1 of 1
    • Place a screw with a washer attached into a hole and tighten it with a 7/32" hex bit.
    • Repeat this process for the other 5 screws and washers.
  5. How to Fix a Wobbly Hydraulic Barber Chair: step 5, image 1 of 1
    • Align the bottom of the seat with the top of the pole, and gently put it back into position.
  6. How to Fix a Wobbly Hydraulic Barber Chair: step 6, image 1 of 1
    • Make sure the seat is properly fitted onto the pole by gently pushing down on the seat.
    • Check the stability of the pole by gently shaking the chair.
Gaurav Tiwari
133 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 63
All Time: 3,637
