How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest
  1. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest, How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: step 1, image 1 of 2 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest, How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: step 1, image 2 of 2
    • Lean back the chair and extend the leg rest completely.
  2. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: step 2, image 1 of 1
    • Lay the chair on its side on the ground to allow easier access to the required hex screws and blocker screw.
  3. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: step 3, image 1 of 3 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: step 3, image 2 of 3 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: step 3, image 3 of 3
    • Remove the 3 mm blocker screw using a 3mm Allen wrench/hex key.
  4. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: step 4, image 1 of 1
    • Slide the leg rest out of the base.
  5. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: step 5, image 1 of 2 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: step 5, image 2 of 2
    • Place the leg rest on a flat surface.
    • Wipe clean the sliding legs using a clean cloth to ensure the sliding mechanism has no issues.
  6. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: step 6, image 1 of 3 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: step 6, image 2 of 3 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: step 6, image 3 of 3
    • Tighten the four 25 mm hex screws located at the bottom of the chair using the 3 mm Allen key.
    • Be careful not to over tighten the 25 mm hex screws. This can cause the screw to become free from the base.
  7. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: step 7, image 1 of 1
    • Slide the leg rest back into the base.
  8. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: step 8, image 1 of 2 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: step 8, image 2 of 2
    • Screw the 3 mm blocker screw back in.
    • Flip your chair back up and enjoy your sturdy leg rest!
Anoop Shahi
157 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 13
All Time: 441
