How to Fix an OXO Container's Jammed Button
  1. How to Fix an OXO Container's Jammed Button, How to Fix an OXO Container's Jammed Button: step 1, image 1 of 3 How to Fix an OXO Container's Jammed Button, How to Fix an OXO Container's Jammed Button: step 1, image 2 of 3 How to Fix an OXO Container's Jammed Button, How to Fix an OXO Container's Jammed Button: step 1, image 3 of 3
    • Hold the lid with the button facing down.
    • Twist the flat part in the direction of the arrows or counter clockwise.
  2. How to Fix an OXO Container's Jammed Button: step 2, image 1 of 3 How to Fix an OXO Container's Jammed Button: step 2, image 2 of 3 How to Fix an OXO Container's Jammed Button: step 2, image 3 of 3
    • Firmly pinch both the half-moon shaped openings.
    • Pull up the removed outer piece and set it aside.
  3. How to Fix an OXO Container's Jammed Button: step 3, image 1 of 1
    • Place the lid perpendicular and onto the top of the container's opening.
    • The button should pop out. Placing the lid on a flat surface will prevent them from coming out.
    • Locate the two holes.
  4. How to Fix an OXO Container's Jammed Button: step 4, image 1 of 2 How to Fix an OXO Container's Jammed Button: step 4, image 2 of 2
    • With a tool in each hand, insert them into the openings of the buttons.
    • Make sure the two tools are centered on the plastic in the openings.
    • Tools must be small enough to fit inside the openings - alternatives to spudgers work.
    • Firmly press downwards until the button pops out.
    • Applying a lot of pressure is necessary, but also may damage the plastic of the lid.
  5. How to Fix an OXO Container's Jammed Button: step 5, image 1 of 2 How to Fix an OXO Container's Jammed Button: step 5, image 2 of 2
    • Flip the lid so the button faces up.
    • It should be easy to pinch the sides of the button so that it pops up.
    • Pinch the two sides and gently pull up.
    • Remove the button.
  6. How to Fix an OXO Container's Jammed Button: step 6, image 1 of 3 How to Fix an OXO Container's Jammed Button: step 6, image 2 of 3 How to Fix an OXO Container's Jammed Button: step 6, image 3 of 3
    • Flip the button so the inside wire faces upwards.
    • Use pliers to bend the wire similar to its original shape.
    • Use the unbent wire as a reference to reshape the bent wire.
To reassemble your device, squeeze the button back onto the lid and follow these instructions in reverse order.
Allen Wong
133 Reputation
1 Guide authored
UC Davis, Team 2-5, Andersen Winter 2023 Member of UC Davis, Team 2-5, Andersen Winter 2023
UCD-ANDERSEN-W23S2G5
3 Members
1 Guide authored
0 Comments
Past 24 Hours: 6
Past 7 Days: 30
Past 30 Days: 204
All Time: 3,527
