How to Format a drive in Windows 7-10
  1. How to Format a drive in Windows 7-10, Open File Explorer: step 1, image 1 of 1
    • Open File Explorer.
    • You can do that from either of the red highlighted spots, or search for "File Explorer."
  2. How to Format a drive in Windows 7-10, Open the Format Menu: step 2, image 1 of 2 How to Format a drive in Windows 7-10, Open the Format Menu: step 2, image 2 of 2
    • Right-Click on the drive you want to format, and click format
    • This is what should pop up.
  3. How to Format a drive in Windows 7-10, Format your drive: step 3, image 1 of 1
    • if you will be using the drive for Windows, format it as NTFS. If you need a multi-OS drive, exFAT or FAT32 is recommended. However, keep in mind FAT32 has a 4GB limit on files.
    • Use default allocation size.
    • If you want to rename your drive put the new name here.
    • Start the format. When It's done, you can close all the windows, and you are done.
Finish Line
6 other people completed this guide.
George A.
21,996 Reputation
4 Guides authored
Community Protectors Member of Community Protectors
Community
19 Members
24 Guides authored
0 Comments
Past 24 Hours: 7
Past 7 Days: 36
Past 30 Days: 92
All Time: 1,270
