How to Hack Epson L200's Waste Ink Pad
Angela Penaherrera
Angela Penaherrera and 2 other contributors
Last updated on June 18, 2024
15 minutes
Easy
Featured Guide
Community-Contributed Guide
Introduction
Go to step 1
The Epson L200 and similar ink tank models are great, the ink replacements are very efficient and let you print much more for the money it costs replacing them. The big flaw is the waste ink pad.
The printer has a limited amount of times that it can clean the printer's nozzles and do a power ink flush to clean the printer heads. Once the printer reaches it's limits it's software will block you from printing on any computer. Now this is to protect the waste ink pad from overflowing with waste ink but the printer is designed in a way so that it is very hard to replace it.
First you need a software that is available online from many sites to reset the waste ink pad error counter on your printer, I only found it available for PC from this link: http://appuals.com/step-step-guide-reset...
and after that you can follow this guide and even look for youtube videos on how to do this.
  1. How to Hack Epson L200's Waste Ink Pad, How to Hack Epson L200's Waste Ink Pad: step 1, image 1 of 2 How to Hack Epson L200's Waste Ink Pad, How to Hack Epson L200's Waste Ink Pad: step 1, image 2 of 2
    • A wild Epson Printer appears.
    • Turn it around and look for a small door.
  2. How to Hack Epson L200's Waste Ink Pad: step 2, image 1 of 2 How to Hack Epson L200's Waste Ink Pad: step 2, image 2 of 2
    • Locate the small door on the back and open it.
    • You will find the tube that drains the waste ink to the ink pad.
  3. How to Hack Epson L200's Waste Ink Pad: step 3, image 1 of 1
    • As you can see, the pad is full with waste ink and is larger than the small door that gives you access to it, meaning it is not meant to be changed by mortals.
  4. How to Hack Epson L200's Waste Ink Pad: step 4, image 1 of 2 How to Hack Epson L200's Waste Ink Pad: step 4, image 2 of 2
    Tool used on this step:
    • With a pair of tweezers gently pull the ink tube from the ink container.
    • Be careful not to grab it from the tube so as not to damage it.
  5. How to Hack Epson L200's Waste Ink Pad: step 5, image 1 of 3 How to Hack Epson L200's Waste Ink Pad: step 5, image 2 of 3 How to Hack Epson L200's Waste Ink Pad: step 5, image 3 of 3
    Desoldering Pump
    $3.99
    • With the help of a syringe or anything that can suck liquid, clean the remaining ink from the tube.
    • I also went ahead and cleared the pad from as much ink as I could, it can buy you a bit more life span to the pad if you are in a hurry to print and not have the replacement items for this hack.
    • I did not have a syringe at the time and used a desolder pump, takes way longer though.
  6. How to Hack Epson L200's Waste Ink Pad: step 6, image 1 of 2 How to Hack Epson L200's Waste Ink Pad: step 6, image 2 of 2
    • Cut a 6" piece of the aquarium tubing and grab a connector.
    • Connect the printer tube to the aquarium tubing you just cut with the connector.
  7. How to Hack Epson L200's Waste Ink Pad: step 7, image 1 of 1
    • Put a connector on the end of the aquarium tube and connect it to the top of the bottle. Make sure that there is no chance of spilling or else you will have a big black spot of ink under your printer.
    • I inserted another connector on the top side of the bottle to release any pressure created by the ink coming in and the air in the bottle.
  8. How to Hack Epson L200's Waste Ink Pad: step 8, image 1 of 1
    • I placed the bottle in a lower elevation than the printer so that the ink can travel down the tube easier.
    • Check periodically to empty the waste ink bottle.
    Great idea. You are very smart)))
    Anar Farzaliyev - Reply
17 other people completed this guide.
Angela Penaherrera
12,604 Reputation
5 Guides authored
13 Guide Comments
I have the same problem. I will try that step. Good instructions. Thank you.
Adi Priyono - Reply
Thanks for this! =) God bless!
CHRISTOPHER L. BIRUNG - Reply
i need the ressetter for an epson l310
thandolwenkosim - Reply
will this work on L220?
Andi Lesmana - Reply
anyone have try this?
eufrasiaaa - Reply
thank you very much it really helped me
Rupesh Gupta - Reply
Thank you for your guide
rsahirani - Reply
Epson l200 resetter adjustment software is a program to reset the waste ink pad counter on your printer. <a href="https://epsonadjprog.blogspot.com/2019/0... ">Epson L200 resetter</a> thank you
Priya Palukavali - Reply
The printer shall still generate waste ink counter (wic) how to reset the counter without buying the reset code.
bal_pk - Reply
you can use this waste ink to black tank again
Bikramdeep Singh - Reply
That was the easy part. The problem part is that the printer is keeping count of how many cleaning flushes it does, and at a certain number will stop printing until you either get a new one or reset the counter.
Keith Odom - Reply
Did you notice that I included information on your comment in the guide description? Other users also replied with information on how to reset the count. Hope that helps!
Angela Penaherrera -
Very Nice Thank you
srisrielango - Reply
Past 24 Hours: 3
Past 7 Days: 33
Past 30 Days: 141
All Time: 55,704
