How to Install a Fifth String Shubb Banjo Capo
  1. How to Install a Fifth String Shubb Banjo Capo, How to Install a Fifth String Shubb Banjo Capo: step 1, image 1 of 3 How to Install a Fifth String Shubb Banjo Capo, How to Install a Fifth String Shubb Banjo Capo: step 1, image 2 of 3 How to Install a Fifth String Shubb Banjo Capo, How to Install a Fifth String Shubb Banjo Capo: step 1, image 3 of 3
    • Line the capo up along the fifth string side of the fretboard as shown.
    • Line the capo screw holes up about 12 mm from the fifth fret bar and about 4 mm from the face of the fret.
    • Be careful not to line the capo screw holes up directly below a fret bar or directly on top of a fret marker.
  2. How to Install a Fifth String Shubb Banjo Capo: step 2, image 1 of 1
    • Use the marker to mark where the screws should go.
  3. How to Install a Fifth String Shubb Banjo Capo: step 3, image 1 of 1
    • Use the drill to drill both holes for the two screws.
    • The holes should be drilled about 1 cm deep
    • You may need to borrow an extra pair of hands to help you stabilize the banjo while you perform this step.
  4. How to Install a Fifth String Shubb Banjo Capo: step 4, image 1 of 2 How to Install a Fifth String Shubb Banjo Capo: step 4, image 2 of 2
    • Use the flat head screw driver to insert and tighten the screws.
  5. How to Install a Fifth String Shubb Banjo Capo: step 5, image 1 of 3 How to Install a Fifth String Shubb Banjo Capo: step 5, image 2 of 3 How to Install a Fifth String Shubb Banjo Capo: step 5, image 3 of 3
    • To use the capo, slide the capo finger down to the desired fret.
    • Then, tighten the spring knob.
For more information check out the Shubb fifth string capo website at: http://www.shubb.com/fs/index.html
6 other people completed this guide.
Sara Wier
263 Reputation
1 Guide authored
Cal Poly, Team 23-4, Green Winter 2015 Member of Cal Poly, Team 23-4, Green Winter 2015
CPSU-GREEN-W15S23G4
7 Members
15 Guides authored
1 Guide Comment
thank you. Now, I know how to do and i décide to buy a shubb and to install it
Jean-Denis Del - Reply
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 63
All Time: 7,929
