How to Modify Cliff Sensors so they never signal a cliff
  1. How to Modify Cliff Sensors so they never signal a cliff, Disassemble the sensor Clean or Continue: step 2, image 1 of 2 How to Modify Cliff Sensors so they never signal a cliff, Disassemble the sensor Clean or Continue: step 2, image 2 of 2
    • The sensor is easily disassembled by lifting the two small plastic latches on the side. Once the cover is removed you could clean the sensor and replace it....
    • Since I'm very tired of Error-6 messages and will not be adding stairs to my dirty house I opted to alter the sensor so that it will never detect a cliff falsely or otherwise.
    • These sensors work by emitting an IR light from one side and since there are baffles in the sensor it must bounce off a floor to reach the detector in the other side.
  2. How to Modify Cliff Sensors so they never signal a cliff: step 3, image 1 of 2 How to Modify Cliff Sensors so they never signal a cliff: step 3, image 2 of 2
    • THIS STEP CANNOT BE UNDONE.
    • I removed the baffles from the sensor so that the detector and emitter have a direct line of sight to each other
    • I used a small pair of wire cutters to cut out the baffles as needed
    • I put the Roomba back together and it cleaned until the battery was dead... For the first time in months...
David Miller Lowe
109 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 11
All Time: 3,137
