How to Open Logitech Harmony 1100
  1. How to Open Logitech Harmony 1100, How to Open Logitech Harmony 1100: step 1, image 1 of 2 How to Open Logitech Harmony 1100, How to Open Logitech Harmony 1100: step 1, image 2 of 2
    • Remove the battery cover by pushing down on the circled areas and pushing outward.
    • Remove the battery by lifting up the battery on the corner exposed by the indent in the case
  2. How to Open Logitech Harmony 1100: step 2, image 1 of 1
    • Use a J0 screwdriver head
    • Remove the 3 screws from battery compartment
  3. How to Open Logitech Harmony 1100: step 3, image 1 of 2 How to Open Logitech Harmony 1100: step 3, image 2 of 2
    • Open the connector port on the side.
    • Remove screw with a PH00 screwdriver head.
  4. How to Open Logitech Harmony 1100: step 4, image 1 of 3 How to Open Logitech Harmony 1100: step 4, image 2 of 3 How to Open Logitech Harmony 1100: step 4, image 3 of 3
    • Use plastic opening tool to pry at the open slits on the side.
    • One or two silver foam cubes may pop out of the device. These belong in the slots shown in the third picture. They do not need to go back until reassembly.
    • The plastic connector door will fall off. It will need to be put back upon reassembly.
Keegan Williams
216 Reputation
2 Guides authored
Ohio State, Team 1-5, Garvin Spring 2016 Member of Ohio State, Team 1-5, Garvin Spring 2016
OSU-GARVIN-S16S1G5
3 Members
3 Guides authored
1 Guide Comment
Will changing the battery reset the settings within the remote?
wiboman AT gmail DOT com
Wibo Lammerts - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 14
All Time: 1,571
