How to Open a 17 Inch iMac Flat Panel Disassembly
  1. How to Open a 17 Inch iMac Flat Panel Disassembly, Place iMac Facedown: step 1, image 1 of 1
    • Insert wisdom here.
  2. How to Open a 17 Inch iMac Flat Panel Disassembly, Unscrew Four PH1 Philips Screws: step 2, image 1 of 1
    • Bust out you iFixit toolkit and loosen these four PH1 Phillips screws.
    • These screws will not fully come out!!
  3. How to Open a 17 Inch iMac Flat Panel Disassembly, Remove Bottom Plate: step 3, image 1 of 1
    • Remove the iMacs bottom plate to reveal the first of the goodies waiting inside.
    • Since the screws don’t fully come out, you can use them as a handhold to help remove the bottom plate.
  4. How to Open a 17 Inch iMac Flat Panel Disassembly, Opening the Plastic Case: step 4, image 1 of 1
    • Remove the 4 Torx T10 Screws
Milo Firestar
836 Reputation
3 Guides authored
TechsMexSMA Member of TechsMexSMA
Business
1 Member
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 120
