How to Open the Samsung Galaxy Watch4
  1. How to Open the Samsung Galaxy Watch4, Power down your Galaxy Watch4: step 1, image 1 of 1
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
  2. How to Open the Samsung Galaxy Watch4, Unscrew the back cover: step 2, image 1 of 1
    • Use a Tri-point Y000 screwdriver to remove the four 4.0 mm-long screws.
  3. How to Open the Samsung Galaxy Watch4, Wedge open the back cover: step 3, image 1 of 2 How to Open the Samsung Galaxy Watch4, Wedge open the back cover: step 3, image 2 of 2
    • Insert an opening tool into the seam between the back cover and the metal housing.
    • Twist the opening tool to create a gap.
    • Don't try to remove the back cover all the way yet. The sensor flex cable is still connected to the motherboard.
  4. How to Open the Samsung Galaxy Watch4, Disconnect the sensor flex cable: step 4, image 1 of 2 How to Open the Samsung Galaxy Watch4, Disconnect the sensor flex cable: step 4, image 2 of 2
    • Lay the watch face down.
    • Carefully swing open the back cover by folding the back cover to the opposite site of the created gap.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
  5. How to Open the Samsung Galaxy Watch4, Remove the back cover: step 5, image 1 of 1
    • Remove the back cover.
    • Make sure the rubber gasket is undamaged. If damaged, replace it with a new one during reassembly to maintain proper water resistance.
Adriana Zwink
50,416 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,895 Guides authored
3 Comments
the glass broke on the back of my watch 4 and i have managed to get all the shards and seal out without damaging anything, but I am having trouble finding remplacement glass for the sensor in canada
Champy Ton - Reply
It just suddenly turned off and won't turn on it just vibrates in sequences, i don't know what to do.
Salim Juma - Reply
I am having a real tough time unscrewing the screws despite having the right screwdriver. It is like they are stuck on.
Mishaal Jadunundon - Reply
Past 24 Hours: 18
Past 7 Days: 87
Past 30 Days: 400
All Time: 7,113
