How to Patch a Hole in Jeans with Wool
  1. How to Patch a Hole in Jeans with Wool, Patching a hole in Jean: step 1, image 1 of 3 How to Patch a Hole in Jeans with Wool, Patching a hole in Jean: step 1, image 2 of 3 How to Patch a Hole in Jeans with Wool, Patching a hole in Jean: step 1, image 3 of 3
    • Cut a piece of felt large enough to cover the hole
  2. How to Patch a Hole in Jeans with Wool: step 2, image 1 of 2 How to Patch a Hole in Jeans with Wool: step 2, image 2 of 2
    • Insert thread through the needle hole.
  3. How to Patch a Hole in Jeans with Wool: step 3, image 1 of 3 How to Patch a Hole in Jeans with Wool: step 3, image 2 of 3 How to Patch a Hole in Jeans with Wool: step 3, image 3 of 3
    • Make a loop at the end of the thread.
    • Pull the end of the thread through the loop creating a knot.
  4. How to Patch a Hole in Jeans with Wool: step 4, image 1 of 3 How to Patch a Hole in Jeans with Wool: step 4, image 2 of 3 How to Patch a Hole in Jeans with Wool: step 4, image 3 of 3
    • Grab the end of the jean with your hand.
    • Pull the jean towards you, making it inside out.
    • Place the felt on the hole.
  5. How to Patch a Hole in Jeans with Wool: step 5, image 1 of 3 How to Patch a Hole in Jeans with Wool: step 5, image 2 of 3 How to Patch a Hole in Jeans with Wool: step 5, image 3 of 3
    • Pinch together the jean and the felt.
    • Insert the needle horizontally into the jean and edge of the felt.
    • Pull the needle through till the knot touches the felt.
    • Repeat the above steps until the border of the felt is stitched.
    • Make a knot at the end.
    • Cut off excess thread.
  6. How to Patch a Hole in Jeans with Wool: step 6, image 1 of 3 How to Patch a Hole in Jeans with Wool: step 6, image 2 of 3 How to Patch a Hole in Jeans with Wool: step 6, image 3 of 3
    • Grasp the end of the jeans and pull them towards you to turn them right side out.
    • Insert the foam board into the pants and position it underneath the hole.
  7. How to Patch a Hole in Jeans with Wool: step 7, image 1 of 3 How to Patch a Hole in Jeans with Wool: step 7, image 2 of 3 How to Patch a Hole in Jeans with Wool: step 7, image 3 of 3
    • Grab more than enough wool to cover the size of your hole, ensuring it is at least an inch thick.
    • Rub the wool between hands to make a ball.
    • Place the wool on top of the hole.
  8. How to Patch a Hole in Jeans with Wool: step 8, image 1 of 3 How to Patch a Hole in Jeans with Wool: step 8, image 2 of 3 How to Patch a Hole in Jeans with Wool: step 8, image 3 of 3
    • Stab the wool through the jean and onto the foam board.
    • Repeat until the wool is hardened.
  9. How to Patch a Hole in Jeans with Wool: step 9, image 1 of 3 How to Patch a Hole in Jeans with Wool: step 9, image 2 of 3 How to Patch a Hole in Jeans with Wool: step 9, image 3 of 3
    • Rub some soap onto the wool to tangle the fibers.
    • Place the jeans into the laundry machine.
    • Wash on cold and air dry.
    • Wear your cute mended pants!
Finish Line
LiTong Liu
169 Reputation
1 Guide authored
UC Davis, Team 1-2, Whithaus Spring 2024 Member of UC Davis, Team 1-2, Whithaus Spring 2024
UCD-WHITHAUS-S24S1G2
3 Members
1 Guide authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 108
All Time: 162
