How to Prevent a Run or Tear in Tights from Spreading
Audrey Fremier
Audrey Fremier and 2 other contributors
Last updated on June 25, 2015
3 - 5 minutes
Very easy
Introduction
Go to step 1
This guide explains how to quickly and simply reduce the spreading of a hole in nylon tights by applying nail polish. Nail polish is a quick drying substance. If administered to the edges of a run,it will harden the frayed edges and prevent the run from expanding further into the nylon.
iFixit earns commission when you buy through these links.
  1. How to Prevent a Run or Tear in Tights from Spreading, Run or Tear in Tights: step 1, image 1 of 2 How to Prevent a Run or Tear in Tights from Spreading, Run or Tear in Tights: step 1, image 2 of 2
    • Put the ripped tights on for easier repair, or leave them on if you’re already wearing them.
    • Gather clear nail polish and a pair of scissors.
  2. How to Prevent a Run or Tear in Tights from Spreading: step 2, image 1 of 1
    • Locate all potential runs or directions that the rip can expand.
    • Runs will not usually expand horizontally, but be sure to check both vertical ends of the run.
  3. How to Prevent a Run or Tear in Tights from Spreading: step 3, image 1 of 1
    • Gently tug the tights away from your skin to prevent the nail polish from affixing to your body.
  4. How to Prevent a Run or Tear in Tights from Spreading: step 4, image 1 of 2 How to Prevent a Run or Tear in Tights from Spreading: step 4, image 2 of 2
    • Brush a dollop of clear nail polish on all potential runs.
    • Small runs will require just a dab of nail polish while larger holes may require a thin coat.
    • Repeat these steps to all potential runs and loose threads.
  5. How to Prevent a Run or Tear in Tights from Spreading: step 5, image 1 of 1
    • Once the nail polish has dried, you may cut any hanging pieces of thread.
    • The nail polish will take about 1 minute to dry.
    • Be sure to complete this step after applying the nail polish and letting it dry or a new run will form.
These steps can save a pair of tights from becoming too tattered for normal use.
3 other people completed this guide.
Audrey Fremier
261 Reputation
1 Guide authored
Cal Poly, Team 12-1, Green Winter 2015 Member of Cal Poly, Team 12-1, Green Winter 2015
CPSU-GREEN-W15S12G1
6 Members
8 Guides authored
0 Comments
Past 24 Hours: 12
Past 7 Days: 46
Past 30 Days: 155
All Time: 40,578
