How to Reassemble the Palm IIIc
  1. How to Reassemble the Palm IIIc, How to Reassemble the Palm IIIc: step 1, image 1 of 1
    • Reinsert the screen into the case that contains the buttons.
  2. How to Reassemble the Palm IIIc: step 2, image 1 of 1
    • Put the Motherboard back into casing from right to left.
    • Make sure the black clips are securing the motherboard into the casing.
  3. How to Reassemble the Palm IIIc: step 3, image 1 of 3 How to Reassemble the Palm IIIc: step 3, image 2 of 3 How to Reassemble the Palm IIIc: step 3, image 3 of 3
    • Secure the bottom two ZIF connectors into their slots by opening the flap and inserting the ZIF connectors.
    • Gently press down on the flap to secure the ZIF connector. This secures the screen and buttons to the motherboard.
  4. How to Reassemble the Palm IIIc: step 4, image 1 of 2 How to Reassemble the Palm IIIc: step 4, image 2 of 2
    • Connect the blue and red screen cables to the beige box they were removed from.
  5. How to Reassemble the Palm IIIc: step 5, image 1 of 2 How to Reassemble the Palm IIIc: step 5, image 2 of 2
    • Open the ZIF connector box at the top of the motherboard by gently pulling up on the flap.
    • Insert the ZIF tab into the connector box.
    • Gently press down on the flap to secure the ZIF tab in place.
  6. How to Reassemble the Palm IIIc: step 6, image 1 of 1
    • Attach the white box on the end of the red cable connected to the battery into the connector box on the motherboard.
  7. How to Reassemble the Palm IIIc: step 7, image 1 of 1
    • Place the front and back covers around the casing containing the motherboard and screen.
    • Before securing the covers, place the sensor in between the front and back cover at the top of the device.
    • After the sensor is in place between the two covers, firmly secure the front and back covers.
  8. How to Reassemble the Palm IIIc: step 8, image 1 of 1
    • Replace the long screws at the top of the back case with the Philips head screwdriver.
    • Replace the short screws to the bottom of the back case using the Philips head screwdriver.
    • After the screws are in place, insert the stylus.
  9. How to Reassemble the Palm IIIc: step 9, image 1 of 1
    • Gently snap the flip cover back into place where it connects at the top of the Palm IIIc
Finish Line
Angela Arthur
101 Reputation
1 Guide authored
Ohio State, Team 1-5, Buehl Winter 2012 Member of Ohio State, Team 1-5, Buehl Winter 2012
OSU-BUEHL-W12S1G5
5 Members
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 258
