How to Remove Mold From Book Pages
  1. How to Remove Mold From Book Pages, How to Remove Mold From Book Pages: step 1, image 1 of 1
    • Place a piece of parchment paper underneath the affected page to protect the pages beneath it.
  2. How to Remove Mold From Book Pages: step 2, image 1 of 1
    • Use a soft bristle toothbrush to gently brush the top layer of mold from the page.
    • This is to only remove the surface mold. You will remove the harder parts of the mold in the following steps.
  3. How to Remove Mold From Book Pages: step 3, image 1 of 1
    • Apply a small amount of hydrogen peroxide onto a soft washcloth, ensuring it is damp but not saturated or dripping.
    • If you use too much hydrogen peroxide, you run the risk of ruining the page. You can add a little more if necessary, but you can't remove it once it's on the page.
  4. How to Remove Mold From Book Pages: step 4, image 1 of 1
    • Dab the washcloth on the mold repeatedly to remove the residue that did not come off with the toothbrush.
    • Stop dabbing the page with the washcloth when the remaining mold is gone.
  5. How to Remove Mold From Book Pages: step 5, image 1 of 1
    • Use a paper towel to absorb as much moisture as possible from the page. Gently dab at the wet area to avoid smearing the ink or damaging the paper.
  6. How to Remove Mold From Book Pages: step 6, image 1 of 1
    • Leave the wax or parchment paper in place, with the page facing up to dry completely.
    • You can place an object on the corners of the pages to keep the book open if the book will not stay on its own.
    • After the page is completely dry, remove the parchment paper.
After completing all of these steps, let the book dry off for a couple of minutes, or until you noticed that the affected page is dry again. Then you will be able to read the book and/or place it back on the bookshelf.
Lia Hammond
133 Reputation
1 Guide authored
2 Guide Comments
I will definitely try this. I have a treasured book that I've had for years that fell prey to some horrific mould this winter.
It's worth noting at the beginning that some types of mould can seriously harm your health if inhaled. A P2 type mask (or a N95 KN95 mask) will help avoid inhaling spores, especially at the initial dry brushing stage. I'd also wear some eye protection and gloves for both the mould and the Hydrogen peroxide.
Rodney Berry - Reply
For more intensive book-mould rescue advice, the Northeast Document Conservation Center have some more detailed advice, including how to deactivate active mould, freezing and other tricks of the trade.
They are much more hard-core about safety gear than I am as they must deal with this awful stuff a lot. https://www.nedcc.org/free-resources/pre...
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 201
All Time: 877
