How to Remove Rust from a Screwdriver
  1. How to Remove Rust from a Screwdriver, How to Remove Rust from a Screwdriver: step 1, image 1 of 3 How to Remove Rust from a Screwdriver, How to Remove Rust from a Screwdriver: step 1, image 2 of 3 How to Remove Rust from a Screwdriver, How to Remove Rust from a Screwdriver: step 1, image 3 of 3
    • Use a clean rag to wipe the screwdriver to remove any dirt, grease, or debris.
  2. How to Remove Rust from a Screwdriver: step 2, image 1 of 3 How to Remove Rust from a Screwdriver: step 2, image 2 of 3 How to Remove Rust from a Screwdriver: step 2, image 3 of 3
    • In a bowl, stir half a tablespoon of baking soda with 4 to 5 drops of water.
    • Add one eighth teaspoon of baking soda if the mixture is too runny, or 4 to 5 drops of water if the paste is too thick.
    • Adjust the amount of baking soda and water based on the size of the screwdriver.
  3. How to Remove Rust from a Screwdriver: step 3, image 1 of 3 How to Remove Rust from a Screwdriver: step 3, image 2 of 3 How to Remove Rust from a Screwdriver: step 3, image 3 of 3
    • Apply the paste with moderate pressure, while making sure to fully cover all the rusted areas on the screwdriver.
    • If too much pressure is applied, the paste will fall off. If too little pressure is applied, the paste won't stick.
  4. How to Remove Rust from a Screwdriver: step 4, image 1 of 1
    • Allow the paste to sit on the rusted areas for 2 to 6 hours.
    • For heavily rusted screwdrivers, let the paste sit overnight.
  5. How to Remove Rust from a Screwdriver: step 5, image 1 of 3 How to Remove Rust from a Screwdriver: step 5, image 2 of 3 How to Remove Rust from a Screwdriver: step 5, image 3 of 3
    • After 2 to 6 hours, use a toothbrush or some sort of brush to scrub the paste off the screwdriver.
    • Apply moderate pressure in back and forth and circle motions to effectively remove the rust.
  6. How to Remove Rust from a Screwdriver: step 6, image 1 of 3 How to Remove Rust from a Screwdriver: step 6, image 2 of 3 How to Remove Rust from a Screwdriver: step 6, image 3 of 3
    • Rinse the screwdriver with clean water to remove any remaining paste.
    • Hot water that can be comfortably handled will remove the paste better.
    • Do not use boiling water, otherwise you can injure yourself. Make sure to use hot tap water.
  7. How to Remove Rust from a Screwdriver: step 7, image 1 of 3 How to Remove Rust from a Screwdriver: step 7, image 2 of 3 How to Remove Rust from a Screwdriver: step 7, image 3 of 3
    • Using a clean rag, dry the screwdriver by wiping it in a back and forth motion.
    • Make sure the screwdriver is fully dry, otherwise the rust can return.
Finish Line
3 other people completed this guide.
Varun Sharma
226 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 77
All Time: 769
