How to Remove Screen Google Nest Hub
Video Overview
  1. How to Remove Screen Google Nest Hub, Breaking Glue Connection: step 1, image 1 of 1
    • The unit has no retaining clips on the top or bottom but the top where the camera eye is located is the easiest to get a pry tool into. A heat gun is recommended to soften the glue but I found I didn't need it to get the glass off (but my thumb may never be the same again)
    • avoiding going in directly where the camera is your only looking to go a few MM in as the glass is glued on and its just the thickness of the glass top and bottom.
    • Working your way round you should find two studs at each side at around the same level as the glass top and bottom.
  2. How to Remove Screen Google Nest Hub, Remove Screen Ribbon: step 2, image 1 of 2 How to Remove Screen Google Nest Hub, Remove Screen Ribbon: step 2, image 2 of 2
    • Once you get the glass off take care to not rip the ribbon. picture one is the ribbon locked in the closed position (no ribbon shown but the input to the slot is marked with the triangle and the number 1 bottom left )
    • Red arrow shows where to lift the locking arm the blue arrow shows the ribbon insertion direction
  3. How to Remove Screen Google Nest Hub, Clean Screen Area: step 3, image 1 of 1
    • Clean up the excess glue around the edges and wait for your new screen to arrive.
8 other people completed this guide.
Jason Nairn
325 Reputation
1 Guide authored
6 Guide Comments
What width is the tape you used?
Dan Bradnam - Reply
what tape? the new screen had glue round it just popped it back in ( only just noticed now they have added a video! that isn't me)
Jason Nairn -
The link from AliBaba doesnt work. How do i find another?
Chi Akuma - Reply
"on how do I replace orange cable
Kim Quintero - Reply
Past 24 Hours: 6
Past 7 Days: 58
Past 30 Days: 265
All Time: 16,099
