Introduction
This guide requires removing the battery. Removing the battery allows no room for electrical malfunction and also makes the process of removing debris easier. If the Halo RIC hearing aid still does not function after these steps, it is advisable to check for electrical or mechanical defects in the microphones.
Detach the receiver from Starkey Halo Receiver-In-Canal hearing aid.
Place the receiver with its small hole away from the surface.
If you know that there is no problem with the receiver and want to clean the microphone, move on to Step 4.
Take the Hear Clear Receiver wax guard and carefully insert the orange end into the receiver’s hole.
Rotate the wax guard continuously while inserting it, so as to gain a firm grip on the old wax guard.
Gently pull the stick out.
It should have the receiver’s old wax guard attached to it.
To do this with your other hearing aid, follow the same steps written above. If there is no noticeable change in the RIC Receiver, it is recommended to check for electrical or mechanical defects in the microphone.
5 other people completed this guide.
