How to Remove a Label From a Glass Jar
  1. How to Remove a Label From a Glass Jar, How to Remove a Label From a Glass Jar: step 1, image 1 of 1
    • Boil enough water to fill both glass jars.
    • Pour the boiling water into the smaller jar using a tea kettle.
    • The hot water will heat up the glass and melt the adhesive from the inside.
  2. How to Remove a Label From a Glass Jar: step 2, image 1 of 2 How to Remove a Label From a Glass Jar: step 2, image 2 of 2
    • Place the lid onto the jar and tighten.
    • This step is optional if the larger container in Step 3 has a lid.
  3. How to Remove a Label From a Glass Jar: step 3, image 1 of 2 How to Remove a Label From a Glass Jar: step 3, image 2 of 2
    • Place the jar into a larger glass container.
  4. How to Remove a Label From a Glass Jar: step 4, image 1 of 1
    • Pour hot water into the larger jar until the water level is above the label.
  5. How to Remove a Label From a Glass Jar: step 5, image 1 of 1
    • Add a few drops of dish soap into the larger jar.
    • This helps to clean up residue from the label.
  6. How to Remove a Label From a Glass Jar: step 6, image 1 of 2 How to Remove a Label From a Glass Jar: step 6, image 2 of 2
    • Place the lid on the larger container and tighten.
    • This prevents heat from leaving the container.
    • Let the container sit for 10 to 15 minutes or until completely cooled.
  7. How to Remove a Label From a Glass Jar: step 7, image 1 of 2 How to Remove a Label From a Glass Jar: step 7, image 2 of 2
    • Remove the smaller jar from the larger container.
    • Pour the water out of the jar.
    • Peel the label off of the jar.
    • For containers with loose labels, the label will fall off or be able to be slipped off.
    • Wipe off excess residue with a cloth or paper towel.
Finish Line
3 other people completed this guide.
Ridhwan Hasnat
226 Reputation
1 Guide authored
One Comment
Génial ! Je n'y avais jamais pensé. Merci beaucoup !
Josette Léost - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 16
All Time: 420
