How to Remove and Clean the Kenmore 575-0 Float Switch
  1. How to Remove and Clean the Kenmore 575-0 Float Switch, How to Remove and Clean the Kenmore 575-0 Float Switch: step 1, image 1 of 3 How to Remove and Clean the Kenmore 575-0 Float Switch, How to Remove and Clean the Kenmore 575-0 Float Switch: step 1, image 2 of 3 How to Remove and Clean the Kenmore 575-0 Float Switch, How to Remove and Clean the Kenmore 575-0 Float Switch: step 1, image 3 of 3
    • To easily access the float assembly, open the dishwasher and carefully slide out the lower rack.
    • To prevent accidents, make sure the dishwasher is disconnected from both power and water sources.
  2. How to Remove and Clean the Kenmore 575-0 Float Switch: step 2, image 1 of 3 How to Remove and Clean the Kenmore 575-0 Float Switch: step 2, image 2 of 3 How to Remove and Clean the Kenmore 575-0 Float Switch: step 2, image 3 of 3
    • Use a Phillips #1 screwdriver to remove two 5 mm screws from the ends of the bottom cover of the dishwasher.
    • Remove the bottom cover.
  3. How to Remove and Clean the Kenmore 575-0 Float Switch: step 3, image 1 of 3 How to Remove and Clean the Kenmore 575-0 Float Switch: step 3, image 2 of 3 How to Remove and Clean the Kenmore 575-0 Float Switch: step 3, image 3 of 3
    • Loosen the single 5 mm screw at the base of the dishwasher that secures the float switch in place using a Phillips #1 screwdriver.
    • This will enable you to lift, remove, and clean the float located inside the dishwasher beneath the lower rack.
    • Ensure that the lever inside the float switch remains in its position and does not displace when you unscrew the float switch.
  4. How to Remove and Clean the Kenmore 575-0 Float Switch: step 4, image 1 of 3 How to Remove and Clean the Kenmore 575-0 Float Switch: step 4, image 2 of 3 How to Remove and Clean the Kenmore 575-0 Float Switch: step 4, image 3 of 3
    • Find the float assembly positioned near the front, underneath the lower rack.
    • Carefully press on top of the float assembly and then release to elevate the float.
    • Avoid excessive force when lifting, as it may result in damage to the float.
  5. How to Remove and Clean the Kenmore 575-0 Float Switch: step 5, image 1 of 1
    • Check the float for any debris or residue. If it's dirty, clean it thoroughly with warm, soapy water and a soft brush. Also, clean the area where the float was installed.
  6. How to Remove and Clean the Kenmore 575-0 Float Switch: step 6, image 1 of 3 How to Remove and Clean the Kenmore 575-0 Float Switch: step 6, image 2 of 3 How to Remove and Clean the Kenmore 575-0 Float Switch: step 6, image 3 of 3
    • Reconnect the float assembly to its initial position and fasten it securely. Verify that it moves smoothly and without obstruction.
    • Now that the float switch is clean, reinsert the lower rack.
    • Reassemble the base of the dishwasher.
    • Close the dishwasher and turn on the power and water.
Anirudh Chaudhary
133 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 47
All Time: 347
