How to Remove the Back Plate of a TI-NSpire
  1. How to Remove the Back Plate of a TI-NSpire, How to Remove the Back Plate of a TI-NSpire: step 1, image 1 of 1
    • Place the calculator screen facing down, with the back plate facing up.
  2. How to Remove the Back Plate of a TI-NSpire: step 2, image 1 of 1
    • Remove the six 7.3 mm screws from the back of the calculator using a Phillips #000 screwdriver.
  3. How to Remove the Back Plate of a TI-NSpire: step 3, image 1 of 3 How to Remove the Back Plate of a TI-NSpire: step 3, image 2 of 3 How to Remove the Back Plate of a TI-NSpire: step 3, image 3 of 3
    • Slide the latch to the right to release the keypad.
    • Pull the keypad down at the same time.
  4. How to Remove the Back Plate of a TI-NSpire: step 4, image 1 of 1
    • Remove the screw near the bottom of the calculator on the front side.
    • The screw is behind where the keyboard normally sits.
  5. How to Remove the Back Plate of a TI-NSpire: step 5, image 1 of 3 How to Remove the Back Plate of a TI-NSpire: step 5, image 2 of 3 How to Remove the Back Plate of a TI-NSpire: step 5, image 3 of 3
    • Turn the calculator over so the back plate faces up.
    • Use the iFixit Opening Tool to carefully pry the back plate out at the bottom right corner.
    • The prying order is arbitrary. The importance is to pry across the length of the calculator.
    • Repeat the prying step on the middle right side, moving along the perimeter of the calculator.
    • Repeat the prying step on the top right corner.
  6. How to Remove the Back Plate of a TI-NSpire: step 6, image 1 of 1
    • Use your hands to manually separate the now loosened back plate from the calculator.
To reassemble your device, carefully push the back plate back onto the calculator. Then replace the screws back into the back plate.
John Baek
31 Reputation
4 Guides authored
Cal Poly, Team 7-52, Forte Fall 2012 Member of Cal Poly, Team 7-52, Forte Fall 2012
CPSU-FORTE-F12S7G52
5 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 4,595
