How to Repair Broken Concrete Steps
  1. How to Repair Broken Concrete Steps, How to Repair Broken Concrete Steps: step 1, image 1 of 1
    • Remove any excess tiles from the staircase that need repair.
    • Make sure to apply rough grip gloves and eye-protection.
  2. How to Repair Broken Concrete Steps: step 2, image 1 of 1
    • Use a claw hammer and chisel to flatten/smooth the surface of concrete to reduce any unsound or flaking stones.
    • Be sure to hammer and chisel within the flat surface; don't dig too deep into the stairs.
  3. How to Repair Broken Concrete Steps: step 3, image 1 of 1
    • Apply a wet, stiff bristle brush to remove dusted concrete.
    • Firmly and aggressively press against the brush onto the concrete, to ensure all flakes are absent.
    • Make sure to leave no holes or corners untouched before moving onto the next step.
  4. How to Repair Broken Concrete Steps: step 4, image 1 of 1
    • Insert the larger chisel into the bucket of the quick-setting cement, in the motion of mixing.
    • The amount of cement should cover 1/3rd of the chisel before reapplying.
  5. How to Repair Broken Concrete Steps: step 5, image 1 of 1
    • Slowly smear the quick-setting cement onto the surface of the smooth concrete.
    • Use one of the faces of the chisel to press against the concrete with paste.
  6. How to Repair Broken Concrete Steps: step 6, image 1 of 1
    • Using a margin trowel, press firmly towards the quick-setting cement to flatten the concrete from a left-to-right motion each time.
    • Pressing firmly and slowly will result in a more professional look.
  7. How to Repair Broken Concrete Steps: step 7, image 1 of 1
    • After applying the quick-setting cement, reapply your tiles and wait 5-7 hours before hardening.
    • If no tiles are needed for your staircase, wait 5 minutes when surface becomes firm to mold and shape the concrete.
By completing these easy steps on repairing concrete steps, you’re finishing repair will provide a pleasing look and safety for the environment.
3 other people completed this guide.
Barvee
226 Reputation
1 Guide authored
One Comment
Thanks for the repair pointers!
Nikki Mcmullen - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 37
All Time: 1,493
