How to Repair Warped Cabinet Veneer
  1. How to Repair Warped Cabinet Veneer, How to Repair Warped Cabinet Veneer: step 1, image 1 of 3 How to Repair Warped Cabinet Veneer, How to Repair Warped Cabinet Veneer: step 1, image 2 of 3 How to Repair Warped Cabinet Veneer, How to Repair Warped Cabinet Veneer: step 1, image 3 of 3
    • Wipe down the damaged surface with a damp cloth to remove any dust and debris.
    • Allow the area to fully dry before continuing.
  2. How to Repair Warped Cabinet Veneer: step 2, image 1 of 3 How to Repair Warped Cabinet Veneer: step 2, image 2 of 3 How to Repair Warped Cabinet Veneer: step 2, image 3 of 3
    • Apply a thin layer of rubber cement between the peeled veneer and plywood.
    • Press the veneer down from the center in an outwards motion to adhere the veneer to the plywood.
    • Be careful not to get any rubber cement on your hands.
  3. How to Repair Warped Cabinet Veneer: step 3, image 1 of 3 How to Repair Warped Cabinet Veneer: step 3, image 2 of 3 How to Repair Warped Cabinet Veneer: step 3, image 3 of 3
    • Place your brace over the damaged area and keep pressure on it.
  4. How to Repair Warped Cabinet Veneer: step 4, image 1 of 3 How to Repair Warped Cabinet Veneer: step 4, image 2 of 3 How to Repair Warped Cabinet Veneer: step 4, image 3 of 3
    • Maintaining pressure on the brace, apply the first clamp around the pieces.
    • Make sure the clamp is holding the brace flush, then tighten it into place.
    • Add as many clamps as necessary to keep the brace flush.
  5. How to Repair Warped Cabinet Veneer: step 5, image 1 of 2 How to Repair Warped Cabinet Veneer: step 5, image 2 of 2
    • Once all clamps are secured, refer to the rubber cement label to determine the approximate drying time.
    • While most rubber cement will dry within 2-3 minutes, it's a safe bet to leave the clamps secured overnight.
  6. How to Repair Warped Cabinet Veneer: step 6, image 1 of 1
    • After the rubber cement is fully dry, remove the clamps and the brace.
Enjoy your renewed veneer!
Obelia Abarca
303 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 54
All Time: 2,120
