Introduction
If your backpack's drawstring is loose and the closing mechanism isn't working as it should, don't worry! We've got you covered. In just a few simple steps, we'll show you how to repair the string and make your favourite backpack as secure and comfortable as it used to be!
Identify the defective area and assess how large the damage is.
Cut away any damaged threads around the drawstring tunnel, to create a clean surface to repair.
Place the drawstring inside the tunnel.
Turn the edges inside, so that the drawstring is tucked inside.
Pin the folded parts of the tunnel securely in place and prepare the sewing machine.
Tip: For tips on setting up the machine take a look at this iFixit guide.
Depress the sewing machine foot and remove any pins in the way of the sewing route.
Start sewing a straight line from one side to the other and add a lock stitch at the beginning and the end.
Finish the sewing and cut the loose thread to make a neat finish.
🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
