How to Repair a Broken Windowsill
  1. How to Repair a Broken Windowsill, How to Repair a Broken Windowsill: step 1, image 1 of 3 How to Repair a Broken Windowsill, How to Repair a Broken Windowsill: step 1, image 2 of 3 How to Repair a Broken Windowsill, How to Repair a Broken Windowsill: step 1, image 3 of 3
    • Remove any loose, splintered, or jagged wood by hand.
  2. How to Repair a Broken Windowsill: step 2, image 1 of 3 How to Repair a Broken Windowsill: step 2, image 2 of 3 How to Repair a Broken Windowsill: step 2, image 3 of 3
    • Grab three straight sections of cardboard.
    • Apply Vaseline to one side of each section of cardboard by hand. Vaseline will prevent the wood filler from sticking to the cardboard.
  3. How to Repair a Broken Windowsill: step 3, image 1 of 1
    • Hold one section of cardboard underneath the corner needing repair with the Vaseline side facing up.
  4. How to Repair a Broken Windowsill: step 4, image 1 of 2 How to Repair a Broken Windowsill: step 4, image 2 of 2
    • Apply wood filler to the corner by squeezing the tube.
  5. How to Repair a Broken Windowsill: step 5, image 1 of 3 How to Repair a Broken Windowsill: step 5, image 2 of 3 How to Repair a Broken Windowsill: step 5, image 3 of 3
    • Position the other two sections of cardboard on either side of the corner to help shape the filler into a right angle. Place the sides with the Vaseline on them toward the filler.
    • Use a putty knife or plastic butter knife to smooth filler if needed.
  6. How to Repair a Broken Windowsill: step 6, image 1 of 1
    • Remove the cardboard sections before the filler dries completely.
    • Allow the filler to dry for approximately six hours. The filler may take less time to dry if repairing a smaller section of the apron. For dime sized reparations, the filler will take approximately two hours to dry.
  7. How to Repair a Broken Windowsill: step 7, image 1 of 2 How to Repair a Broken Windowsill: step 7, image 2 of 2
    • Sand the filler with 120 grit sandpaper until it is satisfactory.
    • Repeat steps 4-7 if the corner is not the desired shape.
  8. How to Repair a Broken Windowsill: step 8, image 1 of 2 How to Repair a Broken Windowsill: step 8, image 2 of 2
    • Paint the finished corner with the desired shade of paint.
    • Allow the paint 3 hours to completely dry.
Once the paint dries, the project is complete.
Julia Byrd
157 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 6
Past 7 Days: 51
Past 30 Days: 220
All Time: 6,006
