How to Repair a Locket Hinge
  1. How to Repair a Locket Hinge, How to Repair a Locket Hinge: step 1, image 1 of 3 How to Repair a Locket Hinge, How to Repair a Locket Hinge: step 1, image 2 of 3 How to Repair a Locket Hinge, How to Repair a Locket Hinge: step 1, image 3 of 3
    • Use pliers to carefully bend the damaged hinge back into place.
    • You want the hinge to be rounded and hollow, like a straw.
    • Test the hinge with some wire. If you can easily thread the wire through, then you can move on to Step 2. If not, keep bending.
  2. How to Repair a Locket Hinge: step 2, image 1 of 3 How to Repair a Locket Hinge: step 2, image 2 of 3 How to Repair a Locket Hinge: step 2, image 3 of 3
    • Hold both ends of the wire.
    • Place the middle of the wire against a hard edge. Hold the wire so that it is perpendicular to the edge.
    • Straighten the wire by pulling it against the edge.
  3. How to Repair a Locket Hinge: step 3, image 1 of 2 How to Repair a Locket Hinge: step 3, image 2 of 2
    • Bend the wire to match the contours of your locket.
    • If your locket is rounded, your wire will have to be curved. If your locket is straight, your wire will have to be straight.
  4. How to Repair a Locket Hinge: step 4, image 1 of 2 How to Repair a Locket Hinge: step 4, image 2 of 2
    • Cut the wire to a manageable length. We suggest the length of the hinges plus some excess.
  5. How to Repair a Locket Hinge: step 5, image 1 of 3 How to Repair a Locket Hinge: step 5, image 2 of 3 How to Repair a Locket Hinge: step 5, image 3 of 3
    • Match and align the front and back of the locket.
    • The holes of the hinge must be aligned, making a tunnel for the wire.
    • Line up the curved wire to match the locket shape.
    • Feed the wire through the hole of the hinge.
  6. How to Repair a Locket Hinge: step 6, image 1 of 3 How to Repair a Locket Hinge: step 6, image 2 of 3 How to Repair a Locket Hinge: step 6, image 3 of 3
    • Hold the locket closed.
    • Glue the top of the hinge.
    • Glue the bottom of the hinge.
    • Do not glue the center of the hinge.
  7. How to Repair a Locket Hinge: step 7, image 1 of 2 How to Repair a Locket Hinge: step 7, image 2 of 2
    • Hold the locket closed and hammer the side with the hinge and wire.
    • Tap firmly along the hinge and wire to secure.
  8. How to Repair a Locket Hinge: step 8, image 1 of 2 How to Repair a Locket Hinge: step 8, image 2 of 2
    • Cut the excess wire.
  9. How to Repair a Locket Hinge: step 9, image 1 of 2 How to Repair a Locket Hinge: step 9, image 2 of 2
    • The final product, the locket hinge is fixed and the locket can be used.
Finish Line
Daisy J Williams
169 Reputation
1 Guide authored
UC Davis, Team 4-3, Andersen Winter 2024 Member of UC Davis, Team 4-3, Andersen Winter 2024
UCD-ANDERSEN-W24S4G3
3 Members
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 44
All Time: 708
